I 'm running cat6 and satellite coax cable to my new extension. I'm planning to run these in trunking. Is it ok for them to share the same trunking, if I'm planning to use UTP cable? Should I use FTP cable instead?
Thanks rgd, I hadn't thought of screening the coax, I'll look into that. I'm only really getting twitchy as they'll be sharing the trunking for nigh on 20m.
The extension work is coming on apace! The roof timbers are going in, so should be dry in a couple of weeks. I need to upload some pics...
