I agree with getting a high-quality used deck, then taking it to a shop and have it gone through.  Most of these decks on the used market weren't used much, especially after CDs came out, so finding a mid-90s era deck will probably mean a lot less wear than one from before the 90s.
Blank cassette tape is still out there, Maxell still has a lot of the UR series you can buy brand new on Amazon but the sound quality for music isn't as good as the UDXL II was, but it is fairly cheap to buy a brick of them. If you look hard enough you can find the Maxwell XL II but it will cost you about $55 for a brick of 5 instead of $55 for a carton of 20 UL. When buying tape, do not buy any tape over 90 minutes long, the longer the tape is the more that tape can warp due to them having to make longer tape thinner so it could fit inside a cassette; 60 minutes would be ideal, but finding 60-minute tape is extremely difficult.
Also with a cassette deck, you do need to know how and what to use to demagnetize the heads, and clean the heads and capstan rollers, but you have to something different on the capstan rollers or you'll damage the rubber.
When looking at used decks just google them to see if that particular model is a good model, there were a lot of good models, but there were more not-so-good ones.
 Facebook
Facebook Instagram
Instagram
