Cartridge Screws
DistortedVision
243
73
18,870
I'm just setting up my new tonearm - SME IV. However the supplied mounting screws are too long. I have an Ortofon Kontrapunkt B and they screw into the body of the catridge and don't use nuts to secure. I can use the original ones that came with my cartridge but they are brass and the heads are a bit damaged. I want some new silver ones to replace. However, I'm not able to find any.
I need M2.5 x 5mm. I think M2.5 is standard for cartridge screws but I can only found ones longer than this.
I tried my local hardware stores and even the specialist ones don't have any.
Anyone got any ideas please?
Many thanks!
Love to hear your impressions of the IV once it is set-up. Apparently brass screws are better for audio! There is also a little free mod to the SMEs (309, IV & V) which I have done with my 309 which you might want to try once you have got it all sorted out.
