Can you combine Hi - FI with home cinema?
I'm totally new to home cinema although I bought a budget ARCAM HI FI about 10 years ago (CD 62 Cd and A85 amp with KEF Q series floorstanders).
I love the HI - FI but can now invest in a reasonable home cinema.
Is there a home cinema system I can move to that will also allow me to play music cd's at a reasonable standard?
Budget 4-6K
Grateful for any thoughts
John Duncan
With 4k I'd buy this:
http://www.whathifi.com/review/cambridge-audio-751bd
first. I have one in the house. It's a great CD player, but does so much more.
With 4k, I'd be listening to this
http://www.whathifi.com/review/yamaha-rx-v1067
and something like these
http://www.whathifi.com/review/monitor-audio-silver-rx6-av12
or these
http://www.whathifi.com/review/tannoy-revolution-signature
With the whole six grand, I might stick with the Yam, or a bigger brother, or stretch to an Arcam (though be mindful of software glitches), but would absolutely have these
http://www.whathifi.com/review/pmc-db1i-51
I might forego the sub if budget was absolute...
ric71
91
You certainly can. PMC and ARCAM phenomenal.
Consider Monitor Audio Apex (dont necessarily use the Monitor Audio sub) with the Arcam AVR 500 or 600 if space is an issue.
Oppo 95 as a source for all of your audio and movies.
Please don't listen to people who say you can't combine the two as this is just not true.
Demo demo and demo.
Frank Harvey
567
This is one of those questions that could be answered with yes or no. It's really down to the individual's expectations and requirements. Define 'reasonable'...
You should be able to find something good enough with your budget :)
For that money, I'd go for a Primare SP32 av processor and A30.5 or A30.7 power amp. Wouldn't leave much budget for speakers mind... :doh: Still the Primare processors are well known for having a very clean pre amp section, that won't dirty your stereo music.
Maybe wait for the new Audiolab 8200AP processor and 8200X7 power amp. That'd leave you about £3k for speakers, maybe go for Kef's or B&W's all round, then pick up a BK Monolith sub for ~£500.
Dali Ikon mk 2 5.1 speakers
Yamaha 3067
Any BDP you like and use the DAC in the Yamaha.
My two pence. For my mind, the speakers are the most important part of the system.
duaplex
214
I have to agree with David, what is your idea of something resonable? If you want the purity sound that a Hi-Fi setup with give you replicated in an AV setup, then you are not going to get there. Dont get me wrong you will get very sound for your budget, but not as good. There was an article on how to add an AMP to an AV setup on whathifi with a video tutorial. Of course it would involve you physically getting up and unplugging wires etc, perhaps something to consider later on.
Now if an AV is a must, then look no further than the Arcam range the AVR 500 is incredible and is slashed to good price at the moment. If you can stretch go for the AVR600. This is as good as you are going to get for Music in the AV field! It performs very well and being Arcam they know how to make it sing (forgive the pun). Its also no slouch on Movies either!
Hope that helps
dannycanham
You can get great kit for that amount of money but the only way you are going to tell if AV kit gives a good enough experience for you is to try some 4-6k pure audio kits and some 4-6k AV kits and see. If I had 4-6k to spend on kit it wouldn't go on AV kit. I know I would enjoy music on alot of AV setups at that price. However I'd be happier with what I can do with that sort of money on hi-fi.
CnoEvil
556
14
Hope that helps
Very fair assessment. When I was looking to find a 2 channel amp to better the AVR 600 (biamped to L&R) for music, it saw off some serious hifi amps.....for my taste anyway. It took a remarkable Class A amp to move the sound up to another level. IMO. It is better for playing 2 channel music (stereo direct), than it has any right to be.
Thanks very much for everyones advice
What I've taken from it is:
Demo any kit!
Compare systems and performance in the shop. I'm probably tending towards leaving the HI - FI and home cinema separate but we'll see.
CnoEvil
556
14
I agree with DC in that for a given budget, you can always achieve a better sound with 2 channel....... and you can still get good enjoyment from films by adding a sub (2.1).
If you want to enjoy the full AV experience as well, you have 3 options:
- Totally seperate systems in different rooms, which is the ideal, but has a duplicification of resources and takes up 2 rooms (obviously).
- A musical AV amp (like the Arcam), which gives a good account of itself for both, and has the simplicity of only being one box.
- Buy a budget AV amp with pre-outs + Stereo amp of your choice (provides Front L&R for AV, and works normally for 2 channel). This is often a good choice where music is much more important than AV. The downside is that: AV will be compromised due to the budget AV amp; there could be a slight mismatch of tone between the Centre and the L&R; and there is a bit more faff setting up and using (especially if the stereo amp doesn't have HT by-pass).
IMO The two Arcam amps are so good for 2 channel, that they meet the needs of most people.
FrankHarveyHiFi said:
You can buy the most expensive speakers you like, but it'll be a waste of money unless you have the right amplification driving them.
Precisely why I suggested the excellent 3067, rather than a super-budget design. It's the spending silly amounts on a BDP that puzzles me these days.
