Frank Harvey
CnoEvil said:.......but without recomendations, the OP doesn't know where to start looking for it......... 😉
Thats where his local dealer comes in 🙂
Of course, this section tells us more than most offer to go no...
robbartholomew said:This is used for the analysis of (mostly) classical music for ‘A’ Level music lessons and exams. We are looking for detail and clarity and the ability to differentiate one instrument from another.
For analysis purposes, you need a faithful speaker that isn't going to change what you're supposed to be hearing, and a prett neutral amplifier too.
As a nice and easy option, you could look at the Dynaudio Xeo3 wireless speakers. These are active speakers whose internal crossovers are active (electrical) rather than passive, and each of drivers have their own dedicated power amplifier. There are certain benefits for active speakers, but those benefits can be a little too much for some, so an audition is recommended. Other than a mains cable from each speaker to a wall outlet, there are no other wires around them. You get a small box which has various inputs into which you plug in your source components, and this transmits the signal wirelessly, so the 'system' can be placed anywhere in the room.
Alternatively, the KEF LS50 and a Pioneer A50 amplifier combination is pretty neutral and very good for revealing detail. Many speakers will add their own colorations, but the KEF's have been designed as a modern day BBC LS3/5a (for whom KEF made the drivers and helped in the design). Suffice to say that the performance of the LS50 is light years ahead. Also check out the Primare I22 amplifier.
9x6 metres is a large space to fill effectively, and many small speakers will struggle. For that sort of space, I would normally recommend floorstanders, but a good quality pair of standmounts will sound better. Even though the LS50's will be more revealing, I would probably recommend the KEF R300's, which are a three way design, more efficient, and will have a better low end performance - these will fill that sort of space better. You can also look at the PMC Twenty.22's, and the Monitor Audio GX50 or GX100. The floorstanding B&W CM8's might be worth a look too as they aren't a bass heavy speaker, and sound a little more open and revealing like a standmount speaker.
More efficient speakers will generally sound better at lower volumes (and when they're driven by a suitable amplifier).
