Can anyone please help diagnosing cause of excess voltage in amplifier causing one of the output channels to blow
Denon PMA-2500NE Amplifier fault history in detail;-
Works fine from new for nearly 6 months. No glitches. Used daily.
Connections;-
SACD player both analogue RCA and Digital Co-ax
Turntable to Phono input
Mac via USB
AV receiver to HT Bypass (EXT.PRE)
Fault 1
For no reason, having been used without issue the previous day and for the previous few months, a minute or two after turning on and working fine it cuts out and blinks red. Volume only at 9 o’clock. Source digital co-ax 1 in from SACD player. All other supplies in either turned off or on standby. Amplifier circuit has failed.
Fault 2
Back from repair connect only digital co-ax 1 to SACD (and possibly analogue RCA to SACD??) and speakers and play SACD player, volume at 9 o’clock
1st time on works fine for one or two minutes and then cuts out and blinks red. Amplifier circuit has failed.
Fault 3
Brand new replacement amplifier using existing power lead.
Connect everything up including HT Bypass (EXT.PRE) but everything either off or on standby. Turn it on with volume at zero. Fine. Scroll through input selector and notice hum on HT Bypass which there had never been on the first amplifier before there had been any faults. Seconds later it cuts out and blinks red. Amplifier circuit has failed. The AV Receiver was in standby. Note the AV receiver was not connected to HT Bypass when fault 2 occurred. I did not scroll through to HT Bypass immediately before fault 1 or 2 so don’t know if there was a hum.
All faults occurred when the amp was cold and on for a only minute or two and the volume low. Speaker cable connected correctly - indeed all connections as they were when fully working.
History of fault testing;-
Speakers tested on various amplifiers - All good
Speaker cable tested with Pioneer A400 - All good
They are factory Airlock terminations with banana one end and spades the other. No visual damage
AV Pre Out input and Turntable input tested with Pioneer A400 - All good
Denon DCD-1600NE SACD player tested with Pioneer A400 analogue RCA - All good. Note not tested with digital co-ax as no digital input. Fault 2 occurred with digital co-ax from SACD player.
All testing done from the same electrical socket as was used when the fault occurred - All good. This socket was also used for other things when the amp was away for repair with no problems and other components on the same ring main (hifi, AV receiver, TV etc) never had any issue on the 3 times the amp fault occurred. Also checked by an electrician.
Someone kindly suggested;-
“I don't think there is a problem with the speakers, because even if there was an issue, with volume at 9 o'clock, over current protection would switch amp off without causing any damage to the output transistors. Outer bit of Coax's socket is internally connected to ground. Your SACD was connected to that socket every single time, right? Many points in the amplifier circuit have predefined, safe voltage values compared to the ground=0V. If that gound has a positive value (+1,2,3V..ect), voltage of those safe points will change. Unfortunately, rapid red flashing means high DC voltage on the speaker outputs aka shorted power transistors. Obviously this is just my theory, but I would take a closer look at SACD player.“
Thank’s to Coronavirus I have not had the chance to have the SACD player tested under warranty (Sontec engineers are fuloughed), however does the fact it is working ok with analogue RCA rule this out? What are other possibilities?
I am needing to get the amplifier repaired, however once done I don’t want a repeat of the fault and need to find out the cause
Connections;-
Mac via USB
Fault 1
Fault 2
Fault 3
