Cambridge Audio firmware update
Mycroft Holmes
23
Hello,
a few days ago my Cambridge Audio CXN got a new firmware update.
Usually you see some progress messages on the screen, e.g. downloading this, installing that, etc.
This time instead the display got stuck on "Downloading 90%", it froze for a while, then the unit rebooted and apparently everything was installed ok and apparently the device works.
So my question is: how do I verify if the firmware was installed correctly?
Is a firmware installation a "hit or miss" thing?
thanks
MH
Hello,
thanks
MH
is there no ability in the menu to see what version is installed?
Mycroft Holmes
23
the version reports the "new" number, so, as far as I can see, the installation was indeed executed.
however I don't know if the installation was "atomic": in theory you could mess it up by installing a part of the new firmware.
I would hope that the device has some built-in protection and it will refuse to install soemthing that is "incomplete" or partially corrupt.
