HiIt doesn't look like you've got a dedicated subwoofer output on that A500 Shaun (you can check and confirm that).
If you really wanted to do it, you could choose a sub with speaker-level inputs, which would connect to the A500's speaker outputs.
This method would use a bit of the A500's output power, which is less than ideal.
With no dedicated SW output (on a rear RCA socket) I would advise you not to bother with a subwoofer.
Your money would buy you WHF's favourite cheapie:Hi Gary
I have another question.
I have a pair of old Tannoy Revolution R3’s. I’m on a tight budget at the moment,Max £300 for a new amp. What would you suggest?
kjnd regards Shaun
....which has a phono input if you've got a turntable.![]()
Onkyo A-9010 review
If you’re looking for a musically captivating budget amplifier you’re in luck – the Onkyo A-9010 is a real treatwww.whathifi.com
You'd also have money over to buy a decent Bluetooth receiver or DAC to go with it (if you require some digital connectivity).
If you're not bothered about a turntable input, something like this might do you. In a compact little unit they pack in an analogue input, a DAC for optical, coax and USB digital inputs, Bluetooth reception, a headphone output and what should be adequate drive for your Tannoys (unless you sit miles away in a massive room).
AND Shaun, believe it or not, it's even got the proper subwoofer out that your A500 lacks!
Quite a few people are happy with these. For the price, I'm not surprised. Available in black or silver for less than half your budget:
TOPPING MX3 DAC Power Amplifier 40W×40W Headphone Amplifier Stereo Audio Decoder with Remote Control (Silver): Amazon.co.uk
TOPPING MX3 DAC Power Amplifier 40W×40W Headphone Amplifier Stereo Audio Decoder with Remote Control (Silver): Amazon.co.ukwww.amazon.co.uk
HiBeing 21 years old doesn't mean your A500 has to sound worse than any new budget amp.
Your low bass will depend more on the ability of your speakers - and their interaction with your room, than any difference between the amps.
(Any new amp might have better quality bass, without going any deeper).
Use the Pre Out from the A500 and into line input/s of a subwoofer. This is how I am use Naim Audio’s Uniti Nova > JL Audio Fathom f112 v2 and Audionet’s WATT > JL Audio Gotham g213 v2 as mentioned in my signature.Hi there,
I need some advise.
I have owned a Cambridge A500 from new.
Can I add a subwoofer to it and if so how should I wire it and what are my options?
kind regards
Shaun
I know the R3's well as I used to sell them. My advice is to hold on to your amp as I think a current production amp at around £300 is likely to be a sideways step.Hi Gary
kjnd regards Shaun
