CA 540a Ver 2 amp Cap5 problem
crang
19
Hi all tried searching to see if I can get help with my amp, turned on to listen tonight and when selcting CD I got the 3 flash caps protection light, I checked all the obvious, speaker shorts, In the end I disconnected all leads, still the same result.
Has anyone else had this problem?
Thanks in anticipation
If you're satisfied that there are no problems with your speakers or cabling, I suggest you contact Cambridge Audio customer support. You will need to register first.
http://www.cambridgeaudio.com/sts/
There are also instructions on the site for reducing the sensitivity of the cut out here:
http://www.cambridgeaudio.com/content.php?COID=110&Title=Amplifier+troubleshooting
However, if this issue has just started after a period of trouble-free use, it suggests that there is a problem, so I would strongly advise you NOT to change the sensitivity of the cut out without first consulting Cambridge.
Let us know how you get on.
tractorboy
Many thanks for your input, you confirmed my suspision, have contacted Richer to have a look.Cheers
