Question Bypassing built in turntable preamp
harry0828
I recently bought the Sony PS-LX310BT turntable. I want to upgrade the system by using a integrated amplifier and a good set of speakers. My turntable has the capability to bypass the built in phono preamp using the PHONO/LINE switch - I believe though a phono signal output requires grounding/earthing (?). However, my turntable does not seem to have a grounding terminal anywhere. I've seen similar products, however, such as the Sony PS-HX500 and Pro-ject Juke Box E, have the same capability to bypass the built in phono preamp but these have a grounding terminal.
My question is: if I can bypass the built in phono preamp and use an external one (integrated amplifier), why does my turntable not have a grounding terminal?
Any advice would be appreciated - thanks.
harry0828
Have you had any issues with the turntable in your current system or have you just been using line out?
Thanks for your reply.
No issues. I'm currently using it with the bluetooth connection as I had initially planned to. As mentioned, I'm looking to upgrade the system soon and was just curious re. the lack of a grounding terminal if I have a PHONO/LINE switch.
harry0828
iMark
238
55
18,870
Most likely. Manufacturers will put detachable leads on more expensive models in case people want to "upgrade" their cables. That's when you get a separate earthing lead.
ASK THE COMMUNITY
