Buzz/hum from turntable.
meddlecho
6
I have an AT LP 60 turntable. I plugged it into my amps phono socket & it works very well with no hum or buzz. However, the lead is very short. I wanted to extend it so I bought longer phono leads. With the extended leads I now have a loud buzz & hum. I bought a ground loop isolator but it made no difference. Any ideas or help very much appreciated. Thanks.
TrevC
If everything else is the same it can only be a problem with the new interconnects, perhaps you could borrow some different ones from something else. Is there a separate earth wire on your turntable? If there is, make sure it's connected properly to the amp.
