James7 said:Best of luck.
i do wonder though if you really need active speakers with a digital input. They will need to not only handle 24/192 but have better DACs than the 120 and the whole point of the 120 is that it has excellent DACs. Unless the actives' DAC outperforms the 120 an analogue connection may well be better. There are a number of threads focusing on active speakers, though, and you will find bette advice there than I can offer.
NRMORRIS said:Cheers, point taken. What amp, speakers and analogue lead would you recommend?
NRMORRIS said:Budget is £1000.
