BigH said:Haha, my local dealer made me listen to B&W CM1s. He said Kefs were boomy.
Ha! Good sense of humor that guy.
TrevC said:CnoEvil said:eg. Valve or Solid State; Active or Passive; Class A or Class D;
Not valve, unless you like distortion and unreliability. Class AB preferably. I've never demoed an amplifier in my life, they all sound so similar. Speaker sonic differences are huge however and it would be best to borrow some if you can.
I like pianos to sound like pianos. The Behringer isn't very good at making pianos sound like pianos. It's OK with pop music.TrevC said:I can buy a Behringer amplifier for £150 that exhibits all the desirable qualities that anyone could wish for in an amplifier at any price. High damping factor, low distortion, huge power and a doubling of the available power at 4 ohms compared with 8 ohm impedance loads. I could match this with speakers that cost thousands and the speakers would still remain the weakest link in the setup.
OK, so it looks like carp.
BigH said:davedotco said:Vladimir said:Hypothtical situation:
You have 3000 GBP and you enter a fairly large and well supplied hi-fi store. What do you go to listen to first? Speakers, amps, sources, cables or stands?
Hypothetical answer:
Go to a decent dealer and get him to play you systems that he knows works well at and around your budget.
If you hear a system you really like buy it, get the dealer to install and do not allow him to leave until you are happy.
davedotco said:BigH said:davedotco said:Vladimir said:Hypothtical situation:
I said 'decent', not 'local'............ :read:
My local dealer is a Richersounds, if i want to 'hang out', 'shoot the breeze' or whatever I go to my nearest DV247.
TrevC said:Not valve, unless you like distortion and unreliability. Class AB preferably. I've never demoed an amplifier in my life, they all sound so similar. Speaker sonic differences are huge however and it would be best to borrow some if you can.
BigH said:davedotco said:BigH said:davedotco said:Vladimir said:Hypothtical situation:
Well it was not Richers, it is meant to be a decent one, to be honest I think 7oaks were much better. The problem is many people don't have much choice. Its a nightmare trying to hear some brands with other brands. Try finding a dealer that has Creek amps and Kef speakers for instance.
steve4232 said:If all digital sources sounded the same and equally good, none of these companies making high end digital equipment could exist. Last week I resisted the temptation to audition a £75,000 CD player, not just because I couldn't afford it by a long shot but I did not want to be disappointed with my own system when I got home again!
steve4232 said:This is my last post on the subject as clearly I am in the minority over the value of source components. The consensus seems to be that speakers and amps are everything so why bang my head against the wall pointlessly?
Overdose said:steve4232 said:If all digital sources sounded the same and equally good, none of these companies making high end digital equipment could exist. Last week I resisted the temptation to audition a £75,000 CD player, not just because I couldn't afford it by a long shot but I did not want to be disappointed with my own system when I got home again!
With regard to digital sources in particular, high end equipment merely gives you exclusivity and a lighter wallet. The internals of such a player are likely as not using off the peg PCBs as used in much cheaper and just as capable equipment.
High end companies exist to offer this exclusivity not to offer the pinnacle of audio technology and performance. They also seem quite adept at marketing.
CnoEvil said:Overdose said:steve4232 said:If all digital sources sounded the same and equally good, none of these companies making high end digital equipment could exist. Last week I resisted the temptation to audition a £75,000 CD player, not just because I couldn't afford it by a long shot but I did not want to be disappointed with my own system when I got home again!
How many high end sources have you heard, or is this pure speculation?
IME. The Source is vital, and if expensive, it needs an equally revealing system to show the difference.
To me, it's about where is the best place to put money to get the biggest gain.....in my case, the difference between ADS and MDS was less than that between 203/2s and 205/2s.
chebby said:The problem -at the time - with Linn's source first philosophy was that it almost became 'source only' with magazines recommending a NAD 3020 and a pair of Videoton Minimaxes hung off the end of an LP12! (As some else said, figures of 50 percent, 60 percent and more on the source became the dogma.)
I have always felt that some 'balance' is required. Not slavishly, precisely equal amounts on source, amp and speakers, but not tipped too heavily in favour of one over the others.
A £50 Ion USB turntable feeding a Krell and Magnepans is as silly as the waste of a £10,000 turntable feeding a £50 Bluetooth speaker. These are silly extremes (almost as silly as those seen in some early 1980s system hierarchy charts.)
Overdose said:It's statements like these that show more than a little naivity exists still. All digital sources measure ruler flat, or as near to it as makes no difference. If they don't, then something has gone terribly wrong somewhere.
Vladimir said:Have you been to Jupiter's moon Io to know if its there? Ever seen a molecule with your own eyes?
Or are you just speculating based on measurements?
Given the exact same frequency response and in most cases, an inaudible noise floor, they will not sound different from one another. Level match the equipment and you will remove any perceived differences.
You seem to be erroneously corelating price to performance. True, quality improves with greater expenditure, but in the digital realm this stops fairly early and a simple transparent (and transparent is frankly as good as it gets) DAC can be had for around £100.
