Hi. On the ifi zen what colour do you get in the middle window it will be different between your phone and the echo dot streaming.
H
Hi Middle window is blueHi. On the ifi zen what colour do you get in the middle window it will be different between your phone and the echo dot streaming.
I have a Samsung A40 and the ifi is blue for everything I have playedWhat phone are you using as blue ( has it got writing in there normally ifi ) blue is just the normal basic codec is it blue for everything you play
Hi
Am looking to add a streamer to my system which comprises Marantz 6006 amp and cd player and Dali oberon 5 speakers. Have around £300 budget. I already subscribe to Amazon hd and mainly listen to rock and pop from 1950s to 1980s. Some radio listening would also be good. Any hints/recommendations would be appreciated. Thanks
The zen blue is a bargain as far as cost and audio quality, especially for Bluetooth.All done. Cheers
What do you have to say about the amazon echo link ? any good ? Can we play via airplay ?iPhone or tablet is that using the Amazon app?
Your Onkyo is a network player not a streamer ( if I am not mistaken ) which I know nothing about.
If you can cast to your Echo then you can cast to your amp but you will need Bluetooth to get the signal to your amp. My system consist of an amp and the other things like cd player turntable but when listen to my Amazon Unlimited music I connect to my amp using an ifi Blue Zen which I link to my Echo Dot on the Alexa app on my iPad and then it plays through the ifi blue Zen into my amp. I have two of the Zen Blues on two different systems and they are fantastic okay they cost £129 but they are really good. I also play my Amazon music straight through a set of Bluetooth speakers.
Sorry I really wouldn't know.What do you have to say about the amazon echo link ? any good ? Can we play via airplay ?
