Budget stereo amplifier
omaribraz
I have recently gotten into hi-fi systems and would like to get an amazing set up for my bedroom. I had purchased a set of Denon SCM mission SCM 50's second hand which are amazing. I drive them with a cheap Lepy 2024A+ amp connected to my pc. I was thinking of upgrading my amp and the two which have caught my eye are:
Onkyo A-9010 around £200
Marantz PM6005 around £250
The Onkyo doesn't have a digital input in the UK so I would be connecting it through the 3.5mm speaker out from my sound card to an RCA cable, however, the Marantz has a digital in so I could connect it with an optical cable direct from my PC. My question is:
1. Would the DAC in the Marantz be phenomenally better than using the Onkyo with a 3.5mm cable? (My motherboard has a Realtek ALC889 DAC)
2. Does it make much of a difference if I use a digital cable for stereo as far as I understand digital out is usually used carry 5.1 channels and all I need is stereo?
3. Additionally would buying a stereo amp make a significant difference compared to my current setup?
I have a lot of my music ripped as high quality flac files but recently I do use spotify a lot nowadays.
Best,
O
But it does have a digital optical input which I could use from my PC which has a digital out and most of the amps in that price range did not have any USB inputs sadly.
I will be using it primarily connected to my desktop, i dont think i will be connecting a record player or a CD player. But it will be connected to a set of Denon scm 50 speakers.
Although ALC889 DAC is very good, the audio output from your motherboard may not have the full 2Vrms needed for dynamic headroom in digital media. Using optical connection via the Marantz would be a safe choice and better option than USB.
