Budget(ish) AV amp with pre-outs for stereo?
EarsEarsEars
What's out there at the moment with front L & R speaker pre-outs? I probably only need 5.1, but would prefer something that decodes Hi-Def audio from my blu-ray or whatever. Budget probably up to around £600, but could *possibly* stretch for the right toy...
Or a fifty quid Yamaha 620 from the 'Bay with six-channel inputs fed from the BD55
Garth Man:what about the Yamaha 1065? I think that has pre outs. And it's £509 from Richersounds
I've done this (not from RS) - very happy with it. Pre outs feed a Naim Nait5i for front L & R...
JohnDuncan:Or a fifty quid Yamaha 620 from the 'Bay with six-channel inputs fed from the BD55
I was considering this, but then figured I'd end up spending another couple hundred on five pairs of interconnects!
The Yamaha models with pre-outs start with the 765 at about £370, but the bargain price of the 1065 makes it a better choice over the 765.
EarsEarsEars:
Three pairs. Get them on the 'bay while you're at it
Hiya,
i seen that the denon 1910 was shown to have pre outs? Is this not correct? and would be a cheaper option..........
Just asking as i am also interested.
toebash:
Hiya,
No, it doesn't.
The subwoofer out is sometimes described as a pre out - which I guess it is - which I find misleading...
Thanks Roger,
Thats what i must have taken as pre outs (subwoofer out) Wish they just put it down like that?
toebash:
Hiya,
The 1910 doesn't have pre-outs --- you have to go for the 2310 for pre-outs, which is what makes it's Yamaha equivalent, the 1065 such good value.
EarsEarsEars:What's out there at the moment with front L & R speaker pre-outs? I probably only need 5.1, but would prefer something that decodes Hi-Def audio from my blu-ray or whatever. Budget probably up to around £600, but could *possibly* stretch for the right toy...
What have you been using so far? It seems from your system that you are more into music than AV? If this is the case, I would play around a bit. You could pick up a Sony STR-DA1200es for similar to what you could sell your 640A. You could then get a much better stereo amp for what you are planning to spend on an AV receiver. Just a thought. As for phono cables, three sets of QED Qunex or similar for about £15 a pop would be fine.
Sorry, didn't actually answer your question - I'm just using the blu-ray to feed
the DacMagic with optical then into the Amp with front and rear
speakers + sub.
'sOK, but I'm sure I can do better. I've got Sky+HD arriving soon, so wanted to feed that through the amp too.
