Hi, Im considering rear speakers and I need some advice please. I will only be able to position the surround speakers at the rear of the room i.e not on side walls or on the side with stands but they can be anywhere behind the sofa, to the left and right.
I already have BR5s and a BRLCR for the front. What rears should I go for bearing in mind I dont want them wall mounted and what stands could you recommend? I reckon the BR1s as they are the same size cabinet(width) same size woofer and tweeter cones as the BR5s, the BR2s are bigger and the BRFXs are wall mounted and ideally for side usage.
Many thanks
Matt
Many thanks
Matt
