- Aug 10, 2019
- 2,556
- 5
- 0
I'm going to be using wall-mount bookshelfs as rear surrounds in a 5.1 system. After reading on some sites i was thinking of putting them on the side walls pointing directly across at each other, level with the back of the sofa and about 3ft above ear level. Would this be the best option?
or should they be pointed at the listener and therefore toed in and down?
THX seem to be recommending bi-pole/di-pole but they only do bookshelfs as rears for my speaker package. Would using a different make for the rears still work ok?
Thanks.
Thanks.
