Merry Christmas all, looking for recs on best bluetooth turntable upto £500 (could go a little higher if absolutely needed). Amp is Cyrus One, speakers are LS50s (wired). Many thanks you lovely lot in advance
Thank you nopiano. Don't want bluetooth but logistically need to stash turntable away when not using it and connecting it with cables is a hassle.Can you explain why a Bluetooth turntable? I believe most Cyrus ONE models have a phono stage, meaning a turntable can plug straight in. And if you do use a BT connection you will downgrade the results, rather wasting £500. At £179 for a modest turntable, maybe.
I would choose between and Cambridge Alva ST at £500 and a Pro-ject T1 BT at £429, both available from Richer Sounds. That’s if you must have BT!
I want the sound of vinyl.Sorry sounds like you dont want a turntable. You want the image of one.
attaching the cables is the easy part. Setting up each time you move it is what will take the time.
Good comment. Once set-up correct it's not a good idea to keep moving a turntable.Sorry sounds like you dont want a turntable. You want the image of one.
I might suggest that Bluetooth is not the best means to deliver this....I want the sound of vinyl.
Then forget the whole idea of bluetooth.I want the sound of vinyl.
I’d have a look at jbl’s new offering.Merry Christmas all, looking for recs on best bluetooth turntable upto £500 (could go a little higher if absolutely needed). Amp is Cyrus One, speakers are LS50s (wired). Many thanks you lovely lot in advance
Though I agree with thisThen forget the whole idea of bluetooth.
What twinkletoes said.Though I agree with this
And reading that it sounds like you are not using the BT at all?Jeezo...I'll bypass the snobbery in this thread and recommend the Alva ST. Bought mine a few months ago and rate it.
Bluetooth can be bypassed, much like the comments in this thread, but having used it for low level listening one night with my IEMs, I was pleasantly surprised how decent it was.
The onboard phono stage, based on Cambridge Audio's own Duo, is also very good. I use an external one though, the Musical Fidelity X-LP as that soap gives me a Moving Coil option too. In terms of cartridge, the Alva comes with the okay AT95E pre-fitted, though I've since upgraded to an AT-540ML.
The Alva ST is currently on offer at £399 as part of Cambridge' Boxing Day sale. Highly recommended.
Can you imagine having to set it up and re-level the thing every time you move it?Jeezo...I'll bypass the snobbery in this thread and recommend the Alva ST. Bought mine a few months ago and rate it.
so are you rating it as a BT turntable or as a turntable using an external phono stage?
It's not the Bluetooth side of things so much as always needing to move it.
I can assure you if you're deck isn't level you might as well buy a CD player.....If that's what the OP needs to do, that's their prerogative though, right? And re-level it? What are you thinking it's going on? Rice pudding?!
Let's not overthink this guys. It comes out of storage, it goes on the shelf in the place it'll reside when in use.
Thanks for that. Only been using the medium since the turn of the 1970s so what do I know...and the rack I've used since 1997 is, remarkably, still level.I can assure you if you're deck isn't level you might as well buy a CD player.....
Granted. As long as he is well aware of said issues.Thanks for that. Only been using the medium since the turn of the 1970s so what do I know...and the rack I've used since 1997 is, remarkably, still level.
I'll credit the OP with a modicum of common sense in the matter.
....just in time to become the post of 2023.you can water a lead horse but you can't drink what it makes.
glwts- (s)= sound quality.
