ReValveiT
5.1 is a totally different matter. More power to it. I'm sure it sounds great given it's a whole new multi-channel mix. No problems with that.
ReValveiT said:5.1 is a totally different matter. More power to it. I'm sure it sounds great given it's a whole new multi-channel mix. No problems with that.
altruistic.lemon said:I see. So Hi res is essential for the pros, but bog standard res is ok for us simple folk.
daveloc said:I think any debate about the potential of BluRay for high quality audio has to look at the total package and not just the bigger numbers attached to the raw datastreams.
Take any CD, stick it in a CD player OR DVD player OR DVD-Audio player or SACD player OR BluRay player OR most games consoles OR most computers and press Play and *it*just*plays*.
Take a digital feed from the outputs of pretty much any of the above, and feed it to an external DAC, and the sound improves.
Neither of these things necessarily apply to a BluRay audio disc — they certainly didn't to DVD-Audio and there's no evidence that record company executives have become any more interested in ease of use or sound quality since that debacle.
On the basis of the small number of so-called "audio-only" BluRays I've tried over the last few years, the very best you can hope for is that the disc will halt on insertion till you turn the TV on and work through the (completely arbitrary) menus to select the sound format you want, while being assailed by corporate logos and background sound excerpts you don't wanna see or hear.
In most cases they simply start to play with *some* default format, probably not the one you want, and there's no way to set the player to default to a particular signal type the way an SACD player can be set to default to a layer. You have to stop playback, select the menus, select the signal, restart playback at the beginning (simply pressing play will typically restart where you stopped).
Similarly, attaching an external DAC is often futile because the digital outs are forceably downsampled to 24/48 at best for copyright reasons.
It's true that when you finally get to the playback, having switched off the TV you didn't want to switch on the first place, the sound quality of such discs, whether because of the higher resolution or superior mastering, does appear to be better than the same material on CD. But the hassle of getting to it...
In short, the combination of forced video navigation and forced use of limited quality internal DACs are likely to ruin the BD-audio experience (as it did the DVD-Audio one), and the utility of HFPA, or any other hires launch, depends on eliminating both from the outset.
I have no confidence at all that the suits responsible understand either issue.
You're right, thought, we wouldn't understand hi res. I mean, isn't headroom the amount of space in your bowler?
Tongue in cheek, of course
altruistic.lemon said:It's interesting that the critics, of which there are only a few, don't seem to have read the background material on the Hgh Res blu-ray, but trot out those old truisms which apply to SACD, CD, DVD Audio etc.
None of them seem to be wiling to listen to the new format, nor take it for what it is. Yes, it's a fear reaction (so my psychologist friend says) because it may force a change in to their world, and their beliefs.
altruistic.lemon said:And yet, recordings are mastered at higher resolutions than the CD standard. Why is that?
Andrew Everard said:It's also available in stereo 320kbps MP3 if you want – I know, a flagrant waste of data, but you could always downsample it to 128kbps and then throw the original away.
GRRR has arrived and your comments are spot on. Marrantz ud7007 and Sa 7007 normally work in harmony with BD HD formats and CDs and SACDs and automaticaly switch to the appropriate output. GRRR defaults to a 2 channel PCM /96 the amp says BLURAY DTS Neo 6 music by default and outputs a psuedo 5.1 of very dubious quality. Next turn on the plasma which reveals a very limited menu of 1-50 tracks with no names and the additional output option of HD dts and Dolby. Select one and the amp does not auto switch. After much frustration, the pure direct button hidden under a flap on the amp finally produces a coherent stereo output. Gone is the terrible, confused multi channel mishmash, woolly base and compression and the better recorded tracks are now more than a match for my CDs.
Detractors on this thread are correct, the GRRR example is more dogs dinner than dog's danglies.
altruistic.lemon said:No, we deduce that some amps are difficult to setup
Haven't got mine yet, so will add to this when it arrives. Possibly my not liking the Stones isn't going to help the assessment.
BigH said:Maybe someone will make a BD player that behaves like a cd player?
