Hi just after a sot of wisdom/advice
Just moved from a shoe box flat to a converted chapel and the difference in sound is fairly dramatic getting the sound to fill out and moderate listening levels is proving problematic.
Gear is
Yam as-500, wharfedale 9.6 and sw150 Cambridge CD-10
Room 10mX10m sceiling is bout 2.4m wood floor, non cavity walls moderate decorating (bookshelves, prints, sofa the size of the ark royal)
Sound... Pure direct with a solo or acoustic track sounds.. Well the stuff!!
Hanz Zimmer ie inception sounds a let down pushed or compressed in the mids, a little boxy.
So the vibe is the room showing up the equipment or the equipment letting down the room?
lindsayt
16
A bit of both. The room's showing up the speakers and the speakers are unsuitable for filling a room that size with good quality sounds.
Get yourself a pair of huge speakers and you'll be sorted. Something like Bozak Concert Grands, Klipschorns, EV Sentry III's or Patricians, Altec Model 19's or VOTT.
Oh if only!! I owe my expectations in audio to my dad and he a defiantly a retro audio guy!!
sadly I have had vintage audio in the past and it's beutiful sounding but it's not the recording!!
Bit to coloured for me.
Nice tip tho.
Cant imagine what the tron soundtrack would sound like through any of that lot!!
Nice tip tho.
lindsayt
16
Some vintage hi-fi is coloured. Some is neutral and relatively uncoloured. Most, if not all of the speakers I mentioned are less coloured than Wharfedale 9.6's.
For sure, def consider a change from the dales they do have that soft sound you hear spoke of, thought it would fill out a bit of the space being fairly large heavy old units not the case.......B&W....?? Every time I've heard a pair I've liked floors and shelves? It's the mids not base or treble i'm not finding.. Well believable with the sound at the mo....The goal is very much the in the room sound.
shooter
210
Yep my rooms 8x6x6 ish and what i found i needed was power and lots of it.
I used an amp that had 500 watts on tap at 2 ohms and a pair of standmounts with a pair of drivers in isobaric fashion and a tweeter. This was good but really i need more cones and bigger speakers, i cant help but think a small array would do the job properly but it would never get the nod from the better one.
Now i use actives which are better at getting to decent volumes without cranking the knob.
My advise would be as many watts and the biggest speaker you can get away with 8)
moon
47
supersize me! ... as shooter says. maybe try the Mission MX5's on loan with the yamaha see how you get on.
Moon
BenLaw
475
7
18,895
Nice tip tho.
You don't say your budget, but if it allows and you want uncoloured and effortlessly room filling (they're used in many concert halls) go for active ATC SCM50s or 100s :)
AlmaataKZ
295
Nice tip tho.
+1
If the budget does not stretch, explore some other actives. Many of them have excellent dynamics and can work well at realistic sound levels. Check the "active speakers club" thread for some options.
Also consider adding a sub or two.
