Apologies if this isn't in the right sub-forum. Feel free to move it if necessary. Here's my situation...
I have a Synology 212J NAS box on which I have my music collection. This is sourced from both ripped CDs and vinyl albums recorded on DAT and then re-recorded onto a PC via Audacity and each track & album named manually. All tracks are FLAC quality and have accompanying metadata.
The NAS box is connected to a home network via Ethernet and resides in an upstairs bedroom.
Downstairs is a Yamaha RX-A3010 home cinema amp feeding B&W floor-standing loudspeakers. The Yamaha is connected to my network via Ethernet into a homeplug.
I access and control my collection via a Synology DS Audio app on an iPad Air.
Now here is the problem. Albums recorded live and when previously listened to on a CD move from track to track seamlessly with no break in the music. The only indication of any change is the track number changing on the player.
But when using the iPad to play the same album there is a gap of up to 7 seconds between each track. This kills my enjoyment of the music.
If I use a PC to access the Synology NAS software and load Audio Station then select several tracks to play there is a gap between tracks but it's only 1-2 seconds and that I can live with.
If I play the music on my iPad the gap is also a second or two. That's fine.
So why the big gap between tracks when controlled from an iPad and played on the Yamaha? Is it down to the iPad app? It is much slower than when tracks are played on a PC with wired connections.
Is there any solution to this? The sound quality is fine. And the iPad app is great at making selections. It's just these gaps between tracks that make it difficult to live with. Would a separate player (incorporating a hard drive) connected directly to my amp be better in this respect? Or is gapless music impossible in these setups?
Thanks for your thoughts.
