- Jul 15, 2015
- 15
- 0
- 0
If working to a budget (say £200 for 2 x 2M lengths) do folks favour bi or single wiring for speakers? Kit below.
David Smart said:If working to a budget (say £200 for 2 x 2M lengths) do folks favour bi or single wiring for speakers? Kit below.
Thompsonuxb said:Logically there should be no difference between bi-amping and bi-wiring, if one works so should the other.
Example an amp with two pairs of speaker outs delivers 60watts to each channel is the same as two 60watt amps ran with one set of wire to each individual speaker in the boxes.
We are talking a standard 2way design speaker.
To say one works and improves your sound and the other does not makes no sense.
So to anyone curious I'd always say try it..... See what happens.
andyjm said:Thompsonuxb said:Logically there should be no difference between bi-amping and bi-wiring, if one works so should the other.
Firstly, bi-wiring is a bad idea. If done correctly (correctly badly) by removing the jumper at the speaker, it can lead to a bump in frequency response of the speaker at the crossover point. To be fair, you might be looking for that, but my guess is probably not. Don't do it.
If you really want to run two wires, keep the jumper in place on the speaker. That will effectively parallel up the cables, lowering the cable resistance which is always a good idea.
Thompson, I am afraid that there is a world of difference between using two active devices to power two separate drivers, and running two cables from a single active device. I still don't think that is a good idea, but please take my word for it, it is very different.
What does make sense is an active setup, where the crossover is placed before the amps and then two amps power the drivers in the speaker seperately. High power crossovers in speakers are dreadful (ever looked at one?), far better to have a decent line level filter prior to the amps.
Thompsonuxb said:Naaah I'll not take your word for anything.
A 60wpc amp that has the psu to drive 2pairs of speaker out, How will that differ from two 60wpc amps single wired to each driver......?
We both know a tweeter does not represent a significant load.
So, please go ahead and explain why these two types of wiring differ?
From an amp with a single pair of speaker outs though running two sets of wires could have a negative affect.
But an amp with 2 pairs of speaker outs?
Thompsonuxb said:andyjm said:Thompsonuxb said:Logically there should be no difference between bi-amping and bi-wiring, if one works so should the other.
abacus said:Go to your local professional music store and ask their advice, as they will give you the appropriate cables for the job, (The ones that are used to produce and master the film & music you listen too) which will be of a much better quality (In construction and build) then the cables produced by HI Fi cable manufactures (And promoted by some dealers) at a fraction of the cost. (So called Hi Fi cables are the biggest rip off on the planet today so dont get conned into buying them (Hopefully in the not too distant future they will disappear as a lot of Hi Fi cable manufactures are being investigated by trading standards & the ASA due to the unsubstantiated claims being made)
Hope this helps
Bill
David Smart said:Interesting take on this! My system can accept XLR cables which I guess are more commonly used for pro music. If you have any suggestions on brands or shops?
CnoEvil said:It is misleading to suggest that all the films and music one listens to, are produced and mastered using cheap cables. Cardas, Van den Hul, MIT, Kimber and Transparent are just some of the brands also used in studios.
The arguments about the reason for this and any benefits ensuing from it, will depend on your point of view.
CnoEvil said:You said that recording studios avoid overpriced "hifi" cables, presumably using the "pro stuff", from the likes of Mogami and Van Damme...which in comparison, are cheap.
My research shows that, for example:
- Skywalker Sound use MIT - BOP Studios, designed by Tom Hidley, and probably the most lavish in the world, use Van Den Hul Silver. - Peter Gabriel's Real World Studio, use Kimber. - Bob Ludwig uses Transparent Cables in his Gateway Studio. - David Gilmore at Astoria, uses Kimber - Ocean Way and Grundman Mastering are wired with Cardas.
Please feel free to check this for yourself...for example there is a whole write-up on BOP by Sound on Sound.
