andyjm said:CnoEvil said:You said that recording studios avoid overpriced "hifi" cables, presumably using the "pro stuff", from the likes of Mogami and Van Damme...which in comparison, are cheap.
My research shows that, for example:
- Skywalker Sound use MIT - BOP Studios, designed by Tom Hidley, and probably the most lavish in the world, use Van Den Hul Silver. - Peter Gabriel's Real World Studio, use Kimber. - Bob Ludwig uses Transparent Cables in his Gateway Studio. - David Gilmore at Astoria, uses Kimber - Ocean Way and Grundman Mastering are wired with Cardas.
Please feel free to check this for yourself...for example there is a whole write-up on BOP by Sound on Sound.
Lets suppose you manage a studio. You need to do a refurb, and some cable company says 'let us supply your cables for free' What do you do? .....tough choice.
I found an article some time back about either Air Studios or Abbey Road, I can't remember which. They had updated their studios and a 'name' had supplied the cables. The best the studio manager could say was that 'the cable was easy to strip'. Quite the endorsement.
Although it is ancient history, I have designed studio equipment for a well known broadcaster, including specifying cables. For those interested, Canford carry BBC specified cables - www.canford.com - search for 'BBC' on their site and you are able to find cables to BBC spec. Strangely, no brand names appear. Clearly there must be some mistake.
ID. said:
David Smart said:Thanks. No I haven't tried running jumpers, it looks as if I'm going the single route so will probably order some jumpers as well.
Mr beck said:... i took advice and made the jump and used 4mm van damme cable which is cheaper than most, and i was blown away with the change in sound.
