Gidday people. I'm considering trying a bi-amping set-up for the first time. I'm a 2-channel guy.
I've usually used integrated amps and am currently running an Arcam AVR300 via the internal bi-amping setup it has using channels 6 & 7. It sounds pretty good through my Proac Studio 140 speakers. However, I've just purchased a Perreaux E200 (200W/channel into 8 ohms). It's an older amp (1994 I believe), but with more power and being dedicated to 2-channel it hopefully might offer an improved sound on the Arcam. I'll test it out soon next to the Arcam when I get the Perreaux back soon from its service.
However, my primary question is: would my Perreaux E200 work OK alongside a Perreaux E100 (100W/channel) or even a Perreaux PMF1850 (180W/channel). I'm aware that the amps used for bi-amping should have the same "gain". I have contacted the Perreaux office here in NZ and their very helpful technician has replied to my query noting that the difference in gain between the E200 and E100 would be about 3dB given that the E200 has twice the power of the E100, but that maybe I could try it out to see if it works as theory and practice may differ? What are people's thoughts here? Would the 200W amp work OK alongside the 100W amp given that they are both the same make, and if I were to use the 200W to drive the low frequencies and the 100W to drive the high frequencies?
Another possible option has come up where an older 80's Perreaux PMF1850 has come up for sale and would that one possibly work better with the E200 than the E100 as it is 180W/channel opposed to the 100W/channel E100 and therefore there would be less difference in gain?
Hope this is not too confusing, but I would appreciate anyone's input here about this situation. I was just wanting to try bi-amping as many people say it improves the sound.
Also, out of interest, do you think that the the older 2-channel Perreaux (200W, 1994) will be better than the 7.1 channel Arcam (120W, 2005) I am using presently sound wise? I will try them side-by-side as noted above, but just wanted to hear if anyone out there has any opinions on this. All opinions welcome 🙂.
