John Duncan
Craig M. said:John Duncan said:Native_bon said:Am sure linn will have an explanation to this.
And I think they should provide one.
I think they already have John, buy the expensive one.
:roll:
And I think they should provide one. Perhaps some journalists could prompt them to do so...
BenLaw said:They have once. A second would not only need to explain the findings but also the first explanation. Seems unlikely now.
John Duncan said:if Colin's explanation was wrong, they should say it was wrong (which I see no shame in, tbh), or demonstrate how it was right.
steve_1979 said:I've just tried to ABXing the MP3 and FLAC versons of the track 'House On The Hill'.
With the peak volume levels matced between the MP3 and FLAC versions it's very easy to tell the between the MP3 and FLAC versions every time in an ABX test.
With the apparent volume levels matced between the MP3 and FLAC versions it was much more difficult to tell them apart but I was still just about able to reliably pick out the MP3 version every time in an ABX test.
Hence JD's edit 16 minutes before your post.Mirren Boy said:Ivor's no longer at Linn it's now his sons's company Gilad
Ah. Sorry mirren boy. I'd forgotten about the mod's ability to edit a post without changing it's time.John Duncan said:Well no I think the edit was a bit later than that, but whatever.
John Duncan said:Well no I think the edit was a bit later than that, but whatever. Ivor still appears to be executive chairman btw.
CnoEvil said:- The worst case of "manipulation" was in non-Linn recordings
- The sound quality of Linn's own recordings isn't called into question
CnoEvil said:- The only audible difference between Linn's MP3 and the MP3 that you created, was one of volume....so if the two MP3s versions are volume matched, they are aurally indistinguishable
CnoEvil said:- You can reliably pick the MP3 version from the Flac version of House on the Hill (with peak and apparent volume matched) - can you elaborate what it is that allows you to do this ie. Is the Flac recording superior, or is it down to something else?
CnoEvil said:- Linn's answer is a bit meh
CnoEvil said:John Duncan said:Well no I think the edit was a bit later than that, but whatever. Ivor still appears to be executive chairman btw.
You never can quite trust the young 'uns! :twisted:
steve_1979 said:It would be good if some other people tried comparing these files for themselves.
I've provided links to Audacity, Foobar (with the ABX plugin) and the LAME MP3 encoder elsewhere in this thread.
John Duncan said:He's a tertiary-qualified electronic/electrical engineer from my alma mater, what's not to trust?
Native_bon said:At last what I have know for a long time is now open to most.
CnoEvil said:Tertiary schmerchery!....don't you know the son never quite reaches the lofty heights of the famous father! :roll:
John Duncan said:As my father was apt to point out.
Phileas said:Native_bon said:At last what I have know for a long time is now open to most.
Have you been reading this thread?
