best valve amp for around a £1000
Thaiman
360
[quote user="gthang"]
£1200
http://www.puresound.info/id1.html
An award winner, seen (not heard) one today in the flesh, very smart looking kit, only slight issue for me is only 3 inputs.
[/quote]
Awesome! you will need quite a high sensitive pair of speakers though. Sweet sounding amp that can slam with the best of them.
Also have a look at Hybrid amp (vavle in pre section/solid state power) like DK design (LSA) or Pathos but need to up bugdet a bit more for a good 2nd hand example.
drummerman
540
s/h Audio Innovations Series, Monos-Pre or an integrated. I used to have one and its a neutral, powerful sound. No flab there. Dont be put off by the relatively low power, it sounds like a lot more.
[quote user="Thaiman"][quote user="gthang"]
£1200
[/quote] Awesome! you will need quite a high sensitive pair of speakers though. Sweet sounding amp that can slam with the best of them. Also have a look at Hybrid amp (vavle in pre section/solid state power) like DK design (LSA) or Pathos but need to up bugdet a bit more for a good 2nd hand example.[/quote]
any speakers above 89db should be plenty load enough for normal domestic listening.
