Best system £2500? Bose V30??
Does that mean he would be able to put a blu ray player to it bigboss?
David,any views on my question on the style speaker package?
Wovian:Hey Gerardasnails, thanks for the reply. Have you got a similar idea but more style speaker package. Cheers
Mine is a full size system, apart from my rear two (Monitor Audio R90s - part of the package I mentioned).
As an alternative to Bose, I'd look at either Monitor Audio Radius HD, KEF KHT, or Quad Lite 2's. Only the KEF's are true lifestyle speakers, as the MA's and Quad's are a traditional box type design.
gel:
David has already answered the question
Yes, you can connect the blu-ray player to it.
What about the amp bigboss and frankharvery is that already in the bose system?
Thanks David and if you already owned the AM 15's would you dump them and invest in one of the above you mentioned (probably the KEF's as I probably wouldn't get approval for a box design).
I know that's a personal choice but interested in your view nonetheless.
If I were going for the lifesyle type I'd get the Focal Domes:
http://stereos.about.com/od/reviewsandrecommendations/fr/FocalDome.htm
Not cheap but they are lovely IMO
Had a demo of the focal domes today and they are wicked - I think my mind is made up 😉
gel: What about the amp bigboss and frankharvery is that already in the bose system?
ThanksThe Lifestyle systems (18, 28, 38, 48) are amplified, but the speaker systems available seperately aren't - they're the same as any other speaker package you buy in this respect.
Wovian: Thanks David and if you already owned the AM 15's would you dump them and invest in one of the above you mentioned (probably the KEF's as I probably wouldn't get approval for a box design).
I know that's a personal choice but interested in your view nonetheless.You could keep the Bose, upgrade the system, if needed, then look at upgrading the speakers at a later date.
FrankHarveyHiFi:gel: What about the amp bigboss and frankharvery is that already in the bose system?
The Lifestyle V30 has a media console, doesn't it? Isn't that amplified?
