best subwoofer for movies under £300
nugget2014
215
i want a sub that can reach the lows and give me the feel of bass shake the walls and feel it on my body.
which to buy?
this one
http://www.bkelec.com/HiFi/Sub_Woofers/Gemini.htm
or just a bit over this one
http://www.bkelec.com/HiFi/Sub_Woofers/XLS200-DF.htm
:cheers:
Hi-FiOutlaw said:
this one
:cheers:
This is where I'd put my money, as well.
the gemini II looks good but not sure how much better it'd be compared to the wharfedale diamond sw150 as it doesnt state it's frequency range.plus it's down firing i'd prefer front firing really as dont want neighbours complaining
will have to think about the subwoofers really hard
see how the sw150 sounds at demo tomorrow testing a couple cd's and man of steel on blu-ray hope it makes me think "wow"
BK Subs are excellent value for money.
I wouldnt worry too much about advertised frequency reposne its horse droppings.
What bass you get in your room will be completely different - you will be lucky to get anything below 40hz thats not so modal its over power everything else.
The bass you feel is 50-60 htz and up, in most room the deep bass is lost or not there is enough voluem for you to hear it anyway.
Concentrate on quality - the BK's are excellent - when you have more cash invest in an antimode if your av receiver doesnt have comprehensive bass managment - makes all the difference in an untreated listening room
Almost any sub will make an impression if you have not had one before.
As you get used to what a good sub should sound like, then you get fussier.
The Wharfedale is a good enough vfm budget sub, but as said above, the BK XLS200 is a substantial step up, and almost in budget (well worth the extra imo).
Please let us know how you get on Nugget - I'm interested to know your thoughts once you've heard a few systems
will do jonathan 🙂 would get the bk but downfiring is the only issue i see with it. does downfiring make that much of a difference in shaking the floor?
bigboss said:
BK holds a good reputation, and I suspect it will be superior to Wharfedale. If you don't want a downfiring sub, check this:
http://www.bkelec.com/HiFi/Sub_Woofers/XLS200.htm
did you see this post?
The XLS200 has the FF as well.
Bit out my budget honestly. I've revised my budget down a bit after visting superfi today
Asked about the wharfedale diamond 122s and dont have them in. They sold one pair in a year he even said I don't have a clue why as they had good reviews and sounded good. In 2 weeks I'm going back to demo Dali zensor 3s and the wharfedale sub and some b&w bookshelf speakers. They made a bit of a mistake with what I wanted to demo
It doesnt make any difference what way the speaker is facing, both supposed to sound the same.
Less likely damage down firing speaker.
Wait until you can afford what you want - otherwise you will end up buying twice
