Best sound quality using DacMagic and Foobar2000...
Hi Folks
 I'm using a DacMagic and Foobar2000 playing lossless files through USB.
My question is are there any add on components to Foobar that could improve sound quality? such as ASIO or WASPI drivers?
 Thankyou in advance.
Gary
I use the same combo as you. You can use ASIO, WASAPI or Kernel Streaming for bit-perfect output. Frankly they all do the same job, so if you have Vista just download WASAPI plug-in and you're done.
