Best sound quality? optical or usb?
Chr78
128
Block cvr 100 amp, dali ikon2 mk2 speakers, play mp3s from my macbook that is connected wireless to my apple tv and optical cable from apple tv to my amp. I have an idea that usb direct from my mac to amp would give better quality..
Esra
59
19
Usually an external Dac (Block) should give the better result in sound in comparison to the soundcard of a computer if it is nothing special,so USB.But it´s easy to try yourself.
matt49
51
You can't really compare optical and USB cables, as there will always be other variables involved. USB is asynchronous, optical SPDIF isn't.
Given the choice, and assuming there's no impact in terms of cost or functionality, I'd go for USB because in most cases it will have measurably better performance.
