best settings for samsung 46b650....
they are needed badly folks , or this tv is heading back to the shop tmw , HELP....
i have improved the picture quite a bit , got calibration settings online , still not convinced though , ah sure its early days , the blacks are good , but detail in dark scenes isnt plasma quality , absolutely no clouding , which is great , coming from a panasonic , which has few settings to play with , this sammy is mind boggling , getting there though , motion is fine , colour is very good , perhaps i was expecting too much , its no kuro , nor was my plasma , gonna spin "30 days of night" now on bluray , check out those blacks , if im still not convinced ill be happy with this tv by lunchtime tmw , my budget will be broken , and a 46inch g10 will be sat in front of me ...
ear
118
the 100 hz is good but not as good as the w5500.the blacks are more like blues.but overall its a good set.ive seen B650 and B7000 and B8000 showqing the same movies side by side and....I prefer the B650 image wich seems more natural, altough a little less punchy
well , having had a good few hours now to suss this thing out , it seems the picture can be as good or bad as you want it to be , the 100hz has various settings in itself , get them wrong and it just looks plain weird , simply selecting clear , as most reviews suggest , is perfect to my eyes , at least for movies and general tv , ill check out the footie over the weekend ..
i find the movie preset more natural , plasma like , and seemingly best with sd , selecting natural , and turning down the backlight a tad can give a real punchy look when viewing hd , daylight or bright scenes really sparkle , the usual trade off is dark scenes show a little less detail ..
the option to increase black levels only really makes sense for really sharp animated hd , where you wouldnt notice black crush as much , dialling it in for movies or tv does give deeper blacks , but again , at the expense of detail , so i leave the black enhancer off ..
sd really looks quite good , skin tones look real , not waxy , as long as movie mode is selected , or maybe natural , for high quality sd , bbc , ch4 ch5 etc , any brighter and sd looks a bit cartoonish ..
bluray and bbc hd look very very good , pin sharp , with as much , if not more detail than ive seen on any tv bar the kuro and samsungs led tvs , this actally improved after i installed an update from samsungs website , i dont know what it was , but it helped , the strange thing for me was , when watching various blurays on movie setting , i felt i wanted to switch to natural to get a bit more vibrancy , the downside again being less detail in the darker scenes ( still quite watchable though) i guess this is why the kuro is so good , you get the best detail and vibrancy and the best detail in dark scenes ..
colour is also very good to my eyes , i used the calibrated settings i found online for things like white balance , gamma , custom colours , as i dont have a clue about them
sound is poor , but i knew it would be , a soundbar is on the horizen , to sum up , i think this is a very nice tv , for 1000euros im happy , would i be happier with a g10 ? maybe not as much as i first thought ...
Mode: Movie
Backlight: 3
Contrast: 91
Brightness: 45
Sharpness: 0
Color: 46
Tint: G48/R52
Advanced settings submenu
Black tone: Off
Dynamic contrast: Off
Gamma: +2
Color space: Auto
Flesh tone: 0
Edge enhancement: Off
xvYCC: Off
White balance submenu
R-Offset: 24
G-Offset: 24
B-Offset: 25
R-Gain: 25
G-Gain: 19
B-Gain: 16
Picture options submenu
Color tone: Warm2
Digital NR: Off
HDMI black level: Normal [grayed out]
Film mode: Auto 1
Blue only mode: Off
Auto motion plus 120Hz: Custom
Custom settings:
Blur reduction: 10
Judder reduction: 0
these settings are spot on ...
