Best quality thin speaker wire?
Was going to get some nordost, but its way to expensive,
There seems to be no in between, either 50.00 p/m nordost, or 2.50 QED.
your kit deserves good cable, get yourself some odyssey install cable off e-bay terminated with chord plugs, it is easy to hide, will bend round corners and keep its shape o and it sounds amazing...
But as I said I had a bit of a job getting the micro under the carpet. Chord odyssey deff wont fit.
Thanks for the suggestion though
canada16:
What about the Nordost Flat? It's so easy to terminate yourself if that was your worry...
Looked at that, but could not see anything that cheap.
Do you have a link?
canada16:
thats a real shame it won't fit, its superb cable and so easy to lay under carpet.
