Chisy1 said:I'm on the look out for one of these as well. All the reviews I've read for WD, Seagate, Hitachi etc on Amazon and other sellers have people who are chuffed with them and people who have had real problems. So this isn't really answering your question but as a throw away comment I've read, and it seems to make sense, that you should buy from different retailers to minimise problems in similar batches.
I'll personally be going for 2TB Seagate drives, simply because they appear to be the cheapest of these familiar brands
tremon said:No quality recommendations to give you; most drives outlive their production timespan, so by the time we have meaningful numbers on the quality of a particular drive they're no longer available for sale. Other than that:
- for a NAS you should be looking for drives that are rated for 24/7 operation -- which excludes most desktop drives. Going from memory, I only know about the Western Digital AV series and the Seagate Pipeline drives. Then again, a regular desktop drive might go for years without issue as well, there are no hard rules
- don't worry too much about disk speed. Even the highest-quality video stream in MPEG-4 is only 20Mbps, which is less than 10% of what the slowest drive can deliver -- and most consumer-grade NAS and home networks are not fast enough to really benefit from fast drives anyway
Current harddisk prices are very high, and will probably remain high for the coming months. Were I in the market right now, I would go for the smallest/cheapest drive that can hold my data, and start looking for a better drive in a year.
tremon said:'Enterprise' drives are usually just that: they are intended for business use. That means higher speed, higher reliability, higher longevity and inevitably a higher price tag and higher noise level. If you can afford them, more power to you. The drives I was talking about were these and these (model numbers WDxxEURS, STxxxxVX and STxxxxVM). They are listed as "surveillance" drives in the compatibility list.
RAID is a separate issue. All drives can be used as RAID drives, it's just that WD has modified some of their drives slightly to work better in such a setup. It is completely counter to your understanding: it allows you to combine multiple drives into one disk set. With two drives, you would be using RAID-1, and this would automatically copy (mirror) the contents of one drive onto the other (visual explanation). If you want to use the second drive for manual backups you should not use RAID.
the record spot said:Bought my Western Digital Elements 1TB HDD for £50 off Amazon last year and it's fine. No issues, very quiet, runs cool, USB connection only (mains powered though) and I think you can snag a 2TB for around £70.
Wtf... that's ********. Given those prices, I'd be using desktop drives too. :OPJ1200 said:Looking at some of the 'Desktop' drives available, such as the ones mentioned above by WD, they are pretty cheap: £107 for a 2TB (model number WD20EARX). Seems good.
For a 'Surveillance' version (model number WD15EURS), it is quite a bit more: £460!!!
