Best Bang for Lowest Spend
Witterings
833
548
11,770
A friend who's definitely no audiophile has asked me for some suggestions to upgrade from using an Echo Dot in a fairly large Kitchen Living area with Patio doors out to the garden.
He was about to buy a pair of Sonos 1's but asked me what else he should consider but wanted to keep the spend as low as possible.
I was going to suggest Q Acoustic M20's with a WiiM Mini as a simple alternative but he also wants some ideas for an entry level separates system and I was thinking
Fosi Audio ZA3
WiiM Pro Plus OR Bluesound Nano
Wharfedale Diamond 9.1's
Whilst I prefer the sound of the Nano, the WiiM's are generally more compatible and easy to set as preferred speaker for the Echo Dot to use voice commands with a 12v trigger cable from the WiiM to the ZA3
Is this about the best "entry level" system / bang for the buck that would sound half decent or can anybody think of alternatives that wouldn't be much more but may be significantly better?
Fosi Audio ZA3
Sonos 1's are available for £149, how low did he want to keep his budget??
