Best audio 3d av receiver for around £500.
All you need to do is, remove the label displaying the model number. All amps are the same from the insides. That way, you'll prove to yourself that you're not antichrist.
Wow me and my big mouth - lesson learnt! Last post on the subject.I Agree with Chris 1718....let's talk about hifi and home cinema. It's not rocket science maths anyway and I don't operate at phd level to clear that up. If you are what I think you are then talking about it further - particularly on the maths front - will make you worse not better. Buy an onkyo, yamaha, Denon or pioneer after auditioning!
bigboss said:
Andrew Everard said:
bb, are you turning into the AntiMax?
😀 You know what I mean! Once the model number is removed, there's nothing inside the receiver which will make it antichrist! A typical AV receiver is like this from the inside:
Oh no! Are they green arrows or GREEN TRIANGLES? If they're green arrows I'm fine, however, if they're G***n T*******s, HHHEEEELLLLLPPPP
Why do think I don't eat Quality Street.
Please let me know quickly or this'll be my last post.........................ever.....................probably!
AAAAAAAAAARRRRRRRRRRRRRRRRGGGGGGGGGGGGGGHHHHHHHHHHH
Ok,
Whats the best price for the yamaha rx-v1067 out there.
Ive seen it for £550. Anything better?
Regards.
Assuming you found it here for £549 try checking out your local Richer Sounds give them a ring & they will beat it, if they have it in stock.
Even so that is about the cheapest you will find it.
