lindsayt said:
Very few bass drivers are ideally suited for both. Bass drivers tend to be suited for either sealed box or ported cabinets.
Many if not most midwoofers and woofers these days tend to be suitable for both sealed and ported configurations. The Efficiency Bandwidth Product (EBP) of the driver is an indicator of this with a value less than roughly 50 being suitable for sealed, greater than roughly 100 being suitable for ported and those in the range 50 - 100 being suitable for both.
lindsayt said:
Why half the size? Surely it's up to the designer / marketing department how big the cabinet in any speaker is and not down to whether it's ported or not?
In order to answer the OPs question about the pros and cons of sealed speakers the most obvious thing to do is to use the same driver in a properly configured sealed and ported cabinets. It is physics that determines the reality of this and not the marketing department which may help or hinder the perceived reality.
An optimum size for a sealed speaker is the one that gives a box Q in the range of about 0.5 - 0.85 with 0.7 being the conventional best compromise. The optimum size for a ported cabinet follows from sizing both the port and the cabinet so that the roll off of the output of the driver is exactly matched by the rise of the output from the port to sum to a flat response. If you do this for drivers that are suitable for both loadings you will see the sealed cabinet is roughly half the size of the ported but the ported gives roughly an octave deeper bass extension.
What is nice about physics is that you do not have to take my word for it or the word of a marketing department but can check for yourself if you are prepared to make the effort.
Here is a free program that will allow you to study in some detail the performance of woofers and midwoofers in various speaker enclosures.
lindsayt said:
For the same bass driver, yes. But surely the drivers that are put into any speaker are decided by the designer / marketing dept and not by whether the speaker is ported or not?
Not sure I understand your point. The driver chosen will behave according to the laws of physics. In particular it will follow Hoffman's Iron Law in that you can have only two of high efficiency, small size and deep bass extension but not three.
lindsayt said:
Stick a larger driver into a sealed box and you'll get the same bass extension as a smaller driver in ported speaker. Make the driver much larger and you'll get more bass extension than the ported speaker. All at the expense of cost and domestic acceptability.
Again I am not sure I see your point. If a designer opts to put a large and expensive driver in a large domestically unacceptable sealed box only to get the same performance as a small and cheap driver in a smaller more domestically acceptable ported box then they will need to rely very heavily on marketing to stay in business.
lindsayt said:
Oh yes it does apply in the real world. Listen to a few different sealed boxes vs a few different sealed boxes and you'll soon discover which sounds more realistic in the bass.
This is not my experience where it is mainly the room that determines the quality of the bass given sufficient cone area to generate the SPLs. In an untreated room one can make a case for a sealed speaker but this is less the case in a treated room.
lindsayt said:
You could even do single cycle measurements at various frequencies which would illustrate the problems with transient handling in ported speakers.
If you use the software I linked to earlier it will do this for you. If you put the same driver in an optimum sealed and ported enclosures and look at the group delay you will see the ported driver actually has a better, albeit by a tiny amount, transient response above the frequency the sealed cabinet starts to roll off. Below this the ported cabinet has a significantly worse transient response but maintains a flat frequency response unlike the sealed cabinet.
lindsayt said:
For the frequency range above the roll-off of the sealed speaker the ported speaker is likely to have the better not worse transient response.
Why? Surely that would all depend on factors other than whether the speaker is sealed or ported? Such as driver quality, size of cabinet, etc etc.
Because the two resonances in a ported speaker are at lower frequencies than the single resonance in the sealed speaker. So for frequencies just above the sealed box resonance the sealed box is being influenced by its one resonance whereas the ported speaker is not yet being influenced by either of its two resonances.
lindsayt said:
That may be true in some rooms. The echoey cave / modernistic minimalist type rooms.
What if someone has, for example, a very well furnished room with lots of open bookcases filled with vinyl or books? IE a room that acoustically has some similarities to an anechoic chamber? IE a room with clean bass?
Such rooms will have almost no influence on the low frequency room modes we are talking about here. The bookcases will diffuse higher frequency sound and the furniture will absorb and diffuse higher frequency sound. The absorption of low frequency sound requires large structures.
lindsayt said:
It's up to each of us how we furnish our rooms. Room resonance is something that can be controlled, if anyone wants to.
Indeed but the devices that do it effectively are all large and often best put in false walls and ceilings which is not always an option.
