- Jan 1, 2014
- 215
- 0
- 0
Heard of a few makes. But my sub is a dali ikon sub mk2 which has its Own feet on a plinth so would it not do much difference? Also my sub is on carpet at the moment. Some advice would be good
Alantiggger said:not too clued up on this, it has to be minimal eh ?
themovierooms said:The best upgrade you could buy would be a DSPeaker Antimode to sort the EQ out I suspect.
CnoEvil said:I use an Auralex Gramma (cheaper than the Subdude, but ugglier), as I have a suspended wooden floor. It made a noticeable improvement.
nugget2014 said:themovierooms said:The best upgrade you could buy would be a DSPeaker Antimode to sort the EQ out I suspect.
bit costly. i imagine? can't really afford it, thanks btw (i got my sub from movie rooms for £399 😛)
