BBC (radio) iPlayer via Airfoil - possible??
6th.replicant
294
Have a laptop > Airfoil > Airport Express > DAC setup. Is it, therefore, possible to stream online BBC radio via Airfoil to the Airport Express/DAC? If so, what/which settings do I need? Ta [🙂]
If the content is delivered through the Web browser, just get Airfoil to hijack that. Etc.
Nick21:Hi Rob how's that review coming along?
Andrew Everard:
It would be up by now if I hadn't lost my compact flash card reader containing the photos. I've sold the amps already so I can't do any side-by-side comparisons now. I've done a fair few but they were a few days ago now.
igglebert:If the content is delivered through the Web browser, just get Airfoil to hijack that. Etc.
Sorry to be dull and revert to OT...
But how do I "get Airfoil to hijack" the web browser?
Ta
Easy - airfoil has a drop down asking you what app's audio you want to stream - select whichever browser you're using, and if necessary airfoil will restate that browser to grab it's audio. Sorted...
On the little Airfoil app there should be a bar at the bottom showing the currently playing app, e.g. Spotify. Click on this bar and it should allow selection of any currently running apps.
It may require the restart of the app in question but this will be automatic and most browsers will persist their sessions for you.
6th.replicant:igglebert:If the content is delivered through the Web browser, just get Airfoil to hijack that. Etc.
Ta
open airfoil, there's a tab at the bottom, it probably currently reads "spotify". click it and select your web browser from the dropdown list. if it isn't there, select "other applications" and add it....
Good 'innit. Well Rogue Amoeba, right place right time with Airfoil!
Clicking on the bottom icon of Airfoil will bring up all the possible software options to stream. At the bottom there is "System Audio".
You have to download a plug-in (free) to use it but once you do, anything your computer can play is streamed
Just tested, and yes, iPlayer streaming just nicely!
DavieCee:Clicking on the bottom icon of Airfoil will bring up all the possible software options to stream. At the bottom there is "System Audio"
Though note that that will give you 'badoing' noises through your stereo when mail arrives! Better to use the individual applications (Browser, Spotify, other media player etc) wherever possible...
