Amplifying tv sound via Roksan K2
regimra
Firstly, I'm an 85 year old audio thicko, so need Janet and John book1 handling on all things technical!
Just bought a Neo QLED TV and need to connect it up to my super Roksan K2 integrated amp, so that I can supplement tv sound with Kef speaker output using fibre optic output from Tv via Neoteck DAC converter. Which of the array of input sockets on the amp do I plug into? Is this the way to do it?
Plug your RCA leads (leads with usually, red and white plugs to match the output sockets on the DAC) from the DAC into any line in (other than the dedicated phono input) on the Roksan.
Reactions: nopiano
I suggest using the one marked 'video' as that will make the input selector on the front make sense!
Use the one picked out in gold about three over from the right looking at the back. This is just another 'line level' input like the CD or tuner ports. The one over on the far left saying 'bypass only' is for some other AV surround sound receiver to drive the speakers as the 'front pair' when you haven't got your CD going or whatever.
