Right, so I've got a KRP-500A coming (have I mentioned that?
) but it's coming without speakers, so to enable the other half to be able to watch TV without having to muck about with amps, I'm also going to get a Pioneer amp to go with it, so the Kuro link activates and controls the amp when you press the volume button on the TV remote (I'm also hiding the amp and other equipment, so the only IR receiver on show will be the one on the TV).
I'm either getting the SC-LX71 amp or I might stretch to the LX81, but either way the question is the same, in the reviews for Pioneer's Blu-ray players (which I'll be getting for the same Kuro link reasons) the BDP-LX71 gets marked down largely because the 51-FD model is nearly as good (despite having inferior video DACs?) and much cheaper, so my question is would it be a false economy to get the 51-FD with either of those amps, and more importantly, the screen, or should I save the money and put it towards the speakers, which I also need to buy because I don't think my old KEF Crestas are going to be up to the job? Or, given that the dealer has just got the BD91 model blu-ray in, should I go the whole hog and get one of those? I haven't seen any reviews of it.
So, money no object it's BD-71 (or 91)->SC-LX81,
or
cheap option: 51-FD -> SC-LX71,
or
compromise options: BD-71 -> SC-LX71 or 51-FD -> SC-LX81
What do people think? One other consideration, I WILL be playing music through this, from a Sonos and also vinyl from a Pro-Ject Debut II Phono SB (which might well get upgraded soon...)
Suggestions for speakers would be good as well, bearing in mind the panel will be wall mounted, so the speakers will need to be fairly close to the wall.
cheers!
or
or
cheers!
