mikefarrow said:
hello Rick, my cd player is the musical fidelity xray, amp the matching xa2. both units upgraded by js audio repairs. this made system much clearer with treble in particular more detailed. the units sit side by side on a rigid wood table. my room is 15 foot by 15 foot. my speakers are 5 foot apart and 8 inches from the back wall. unfortunately, any speaker tested would have to go in these exact positions. what i'm after is a fuller more 3d sound. i have a copy of the isotek system set up disk and the "front to back imaging test" confirms my system has zero front to back depth. when records are played featuring drums, there does not seem to be any punch. the system never gives the impression, even slightly, that the sounds/performers are in front of me. the sound is very flat, never seems to fills the room even at maximum volume. i have tried the speakers out in the room as a test but to be honest it makes no difference. am i expecting to much from my cd/amp ? i believe not on the grounds i used to own a £500 technics midi system that although not as clear sounding/accurate as my current system, it did used to give a small but 3d soundstage which gave the illusion that the sounds/instuments were in front of me. the speakers were positioned in the exact spot that my current speakers are. the speakers were also connected with about 10m of bell wire ! i can only guess that the cd, amp and speakers matched perfectly unlike my current (much more expensive) set up. i have been advised that £800 standmounts should give the upgrade i'm looking for so b&w cm5 (which have been advised) plus kef ls50 are an idea. if the cheaper b&w 685s2 are a better choice, great ! or maybe b&w speakers are not to my taste ? either way £800 will take alot of saving! any advice would be appreciated. thanks
Hi mikefarrow
Thanks for your reply.
It just may be that your amp and speakers are not quite suited to each other. Anyway your 601S2's still have more to offer so my advice is that in the first instance look at using alternative amplification -
Rotel RC-972 + RB-971 x 2 bridged configuration
Rotel RC-972 + RB-03 x 2 bridged configuration
Rotel RA-1062
NAD C370
As for speakers you can have a worthwhile upgrade with B&W 601S3's. Alternatively ATC's SCM11 (MK1) monitors, Focal JM Lab Aria 906, and Monitor Audio's Silver 1's are also worth bearing in mind.
Btw, please keep the volume in check with bridged Rotel power amps.
All the best
Rick @ Musicraft
