AVR-2310 remote codes
Loriculus
Hey
Would any one know what remote control code i can use to control an Arcam CD72 CD player with the remote supplied with the Denon AVR-2310? Also the code to control my Samsung Sky+HD box will be useful.
I've tried lots of codes from the manual and none have worked so far (Arcam isn't listed) and I've searched the internet but haven't found anything. And when I search for the Sky+HD codes I seem to get a lot of posts for controlling the Denon with the sky remote which is not what I want.
If not I'll have to spend an hour or so trying every code ^o)
I think Arcam remotes have Philips protocol so you could try the Philips codes (009 or 010) for your CDP.
Cant help with the Sky box - I guess you've already tried the Samsung codes in the sat receiver section of the preset code list.
Other than that, go to the Denon website and email support?
thanks heystak 🙂 009 worked... i tried several manufacturers but Philips wasn't one of them... obviously 🙂
If i dont get a response re Sky HD i'll email denon
thanks
