This year could see an interesting development in AV receivers, if you're a subscriber to Tidal.
Already Anthem's higher end receivers (MRX720 & 1120 but sadly not the entry-level 520) bundle DTS PlayFi which apparently includes Tidal. Well I've just noticed that Onkyo's receivers just released (TX-NR555; TX-NR656; TX-RZ710; TX-RZ810) include a feature called FireConnect by Blackfire that seems quite similar to Yamaha's MusicCast system, but does include Tidal streaming, although this will only work after a firmware update in the summer.
Presumably Onkyo's higher end receivers will follow suit, and you would also think that seeing Pioneer and Onkyo are so closely linked that they would adopt the same technology.
So, in theory at least that adds Anthem, Onkyo and Pioneer to offer native Tidal streaming. It would certainly save me money on a separate streamer from Sonos or Bluesound, so pound for pound it enables me to look at a better quality AVR. The part that appeals to me most about this is that I can then stream to my AVR using the ethernet cable, which ought to increase quality and reduce drop-outs. I tend to manually tether my ipad to my Pioneer AVR already (in its Apple-friendly USB port) but the ipad is still pulling the stream by wi-fi. It's more reliable than Airplay though.
Spotify Connect already seems an almost obligatory feature to any current AV receiver, so it will be interesting to see if Tidal can catch up in this area. So Yamaha, Arcam, Marantz, Denon, when will you be adding Tidal to your repertoire?
