AV Amp - I Can Wait but.......
I have 4 amps in mind (all new) and they are as follows:
Pioneer VSX1019 £699
Onkyo TSXR876 £699
Yamaha RXV765 £549
Sony STRDA2400ES £399
The Amp would be used with:
Pioneer PDP-428XD Plasma TV
Pace Sky HD Box
Nintendo Wii
Panasonic DMP-BD80 Bluray Player
KEF KHT 2005.3 Speakers
Any advice in those amps wpuld be appreciated, also do I wait a month or so?
I know playing the waiting game means that you never commit to a decision and buy a component but I could wait about 4 more weeks for the right amp to come along. I will go to £700 for an amp but not any higher!!!
Ming the Merciless:
Onkyo TSXR876 £699
Yamaha RXV765 £549
Pace Sky HD Box
Nintendo Wii
Hi MtM
Please also consider Yamaha's superb RX-V900. It will work well with your components.They might not be around for long though so if you do decide to go for one than try not to leave it too long.
http://www.whathifi.com/Review/YamahaRX-V1900/
Rick @ Musicraft
The Yamaha RXV1900 is indeed a great amp, but it's way above what he can afford. I would suggest the Yamaha DSP-AX863SE for consideration instead based on his affordability. It costs about £600.00.
pwiles1968
153
Marantz SR6003, in pure AV terms may loose out to some of the others here on specification (Onkyo specifically) but IMHO Musically for 2 Channel an excellent amp. Picked up mine for £640 well worth a listen.
EvilWolf:The Yamaha RXV1900 is indeed a great amp, but it's way above what he can afford. I would suggest the Yamaha DSP-AX863SE for consideration instead based on his affordability. It costs about £600.00.
Hi EW
I appreciate what you are saying however the RX-V1900 can be picked up for not too much more than MtM's budget.
Rick @ Musicraft
MUSICRAFT:
Hi MtM
Rick @ Musicraft
Hi Rick
I considered this amp but I can't find it for £700, I am buying this amp with the KEF's and the Bluray player but still couldn't get it within budget.
I will keep looking.....
Hi EW
This was the amp I originally wanted but since it was discontinued I haven't been able to get it anywhere. I have tried placing orders with several online retailers that were still featuring it on their websites but then the order was either refused or they e-mailed / called me to say they didn't actually have any in stock and cancelled my payment.
Does anyone know where this amp is physically in stock?
You tried hunting down an 'oknyo 875', i seen um going real good prices?
Paulthefilmfan:You tried hunting down an 'oknyo 875', i seen um going real good prices?
Hi Paul
I'm assuming these were refurb ones? I want a new amp, I don't want to pay £500 for a piece of kit that has already failed at least once on a previous owner and may fail again.
I don't know if this is a rational thought / decision, I'm just worried about the life expectancy of a key component. I would buy a new one if they are still out there though, it does look like a cracking amp.
Sorreltiger
42
If it were me, I'd go for a cheaper blu-ray player (Sony 350, for example) to make room in my budget for the Yamaha RX-V1900 as recommended.
I know which choice would make the bigger positive impact, particulary as you have (like me) a brilliant but 768p TV.
Cliff1
Ming the Merciless:EvilWolf:The Yamaha RXV1900 is indeed a great amp, but it's way above what he can afford. I would suggest the Yamaha DSP-AX863SE for consideration instead based on his affordability. It costs about £600.00.
Hi EW
If your still looking.
I went into my local shop a couple of days ago looking for the 765 & found that they had some DSP-AX863s in stock. £587.
P & A Audio Ltd Liverpool.0151 924 7287. Southport 01704 536 901.Been around for a long time.
The one i was going to take with me had been opened & resealed,everything seemed ok,they said that it hadn't been sold & returned, but as they had 2 more in Southport unopened i opted for one of those & they delivered it to me the same day.
Might be worth a try.
kinda
74
I would have a think about the SR6003 as suggested above. Within your budget and I've read elsewhere that it's a rival for amps like the Onkyo 875/876, and RXV1900.
When I was looking for an amplifier, and prepared to spend up to about £1000, I went for the SR6001 ahead of the Onkyos and others. You don't get all the bells and whistles that some have but in terms of sound quality for films and music you get a very good amplifier.
Ming the Merciless:
Hi Paul
I totally understand, i felt the same way until i bought a 'refurb' one but it arrived mint and has been fine so far and it came with a 2 year warranty. I think it may be possible to still get a brand new one for a good price around £499-550. I have also seen the latest '876' as a ex display (mint apparantly) with 3 year warranty free qed hdmi-p all for £699.
Ming the Merciless:
MUSICRAFT:
Hi MtM
Rick @ Musicraft
Hi Rick
Hi MtM
As sorreltiger has suggested spend less on the blu ray player (although i would go for the BD60 instead) and the savings on the RX-V1900 instead. This will give you a bigger return on your investment.
The RX-V1900's can be had for around £800.
Rick @ Musicraft
TheHomeCinemaCentre
70
It is good to see the SR6003 getting mentioned, I would look into this model as well as the RXV1900 ( if you can still find a new one) as it matches if not exceeds the Yamaha's performance at a cheaper price point.
Nick
Hems
108
MUSICRAFT:
Hems:is the rx-v1900 going to be replaced soon?
Hi Hems
The RX-V1900 will be replaced in due course hence why they can be had at a fair price.
Rick @ Musicraft
I should have asked in my earlier post but what is replacing the v1900 and is there a timeframe?
cheers
MrBangle
6
Was also looking for a amp recently.
After listening to quite a few amps
RX-V765
RX-V863
Denon 1910
Onkyo 876
I went for the Marantz SR6003. Beautiful, excellent sound and features. Only downside is 3HDMI inputs which is enough for me but not enough for others.
Hems:MUSICRAFT:
Hi Hems
Rick @ Musicraft
I should have asked in my earlier post but what is replacing the v1900 and is there a timeframe? cheers
Hi Hems
I think the Yamaha RX-V1900 will be replaced by the RX-V2065. I have no details of when this will happen though.
Btw, MtM Yamaha AV amps are and always have been a great match for the various Kef sub/sats.
Rick @ Musicraft
