Audioquest Dragonlfy and the new MacBook Pro
lex365
19
6
18,525
I have been running an Audioquest Dragonfly off a 2012 Macbook Pro to a Nad d 3020 amp and getting some stunning sound however I am encountering some issues since upgrading to the new Macbook Pro 2016. The sound difference is pretty big between the two on account of the new machine sounds a lot worse. Clarity and definition has reduced significantly and everything sounds a little more muffled. The only differing factor is I use a USB C to USB adapter between the Mac and the Dragonfly (the actual set up goes Mac, Jitterbug, Dragonfly, Amp).
I appreciate this may be a little specialist but would anyone be able to advise in the drop in sound quality and clarity? Could this all be down to a USB C adapter sitting between the Jitterbug and the Mac?
lex365
19
6
18,525
I had aside from outputting the mac sounds to the built in speakers. However its leaning towards a USB-C adapter issue as thats the only real variable. the sound actually improves when I remove the DAC and use the heaphone out on the Mac to an RCA adapter where as this has the opposite effect on my old machine.
https://www.amazon.com/nonda-Adapter-Smallest-Aluminum-Indicator/dp/B015Z7XE0A
Can something like this really make a big difference to the quality of the sound?
