Audiolab 8200a problem
Hi guys,
As I power up the amp, when the relay switched on there' a pop sound from the speakers, is this normal?
When each time I change the input selector, there's also a pop sound from the speakers as well.
Something wrong with the amp?
When you power on the 8200A, the mute function activates for a few seconds then unmute. There could be a small 'pop" heard through the speakers at this point. This seems normal. Mine does the same.
When you change input, the mute function should also activate and there should not be a "pop" sound. At least, my 8200A does not produce the "pop" sound when changing input.
