Audio amplifier vs Av amplifier
Blacksabbath25
352
128
19,070
I have asked this on the home cinema thread that I started but need more input form the audio section
i want a home cinema amplifier but do not want to get rid of my Yamaha A-S2100 as I like it very much as I am more into my music then anything but was hoping I could do both .
is it possible to do both as I have been told I could run the main L+Rs on the A-S2100 then use pre-outs to the Av amplifier but been told this can be messy and it's better to get rid of my Yamaha A-S2100 and buy a high end Av amplifier which for me would be the Yamaha 3060 which is £2000 .
i am not happy to part from my Yamaha A-S2100 just to get a home cinema I would rather not bother if this is the case but are home cinema amplifiers like the Yamaha 3060 just as good at music as my Yamaha A-S2100 is because I know the build not going to be the same as my amplifier .
Unless you have enough room to cope with extra speakers (extra expense too!) why would you bother when you have such a good amp - I play my tv and blu-ray through my hifi and 2 speakers - sounds excellent..
It would have to be some av amp to better what you have already.
cheers tonky
cheers tonky
I kind of agree with you
I did not want to go silly In getting a Av amplifier and spending silly money just to make this happen as I would only use a 5.1 setup if I did go for one which the Yamaha 3060 is overkill for my needs .
but I do not feel confident in thinking that a Av amplifier will give me the same music quality as my Yamaha A-S2100 does .
I did the same with hegel.h360.and yamaha 3050
Used the ht bypass and used pre out on yamaha 3050
Worked great.
What you.need to check.is if your yamaha 2100 has an av bypass?
When you.select the av bypass it puts the 2100 close to full power then the av controls the volume for movies.
This way you.have best of both worlds and get to.keep your stereo untouched by av
Worked great.
What you.need to check.is if your yamaha 2100 has an av bypass? When you.select the av bypass it puts the 2100 close to full power then the av controls the volume for movies.
hi Andrew
i will have to find my instructions and find out if it would that will be good if it does
More expense for sure but you might think about adding a three channel power amp to your Yamaha.
But then again it may be cheaper and more worthwhile to keep the two systems completely separate.
I've got some connections on the back of the amplifier that says main-in which the instructions say is for use of a pre-amplifier or a Av amplifier which fixes the volume and I have pre-out jacks too
is this what your talking about ?
If he does that will still need av pre amp or processor so easier just to buy an av amp with pre outs.
Does not have to be the best available
If he does that will still need av pre amp or processor so easier just to buy an av amp with pre outs. Does not have to be the best available
it's says main where the Av amplifier will go but it's not called Av bypass
but basically it says when the power of the connected component is turned on this unit turns on and the input is set to main direct automatically.
Waste of time, money and space just to watch Hollywood garbage. I'd rather go out to the cinema to watch a movie properly. For casual watching a phone/tablet/laptop is good enough.
Buy your wife jewelry instead.
Different manufactures use different descriptions, but main in will be fine, as the instructions say.
I still say have a listen to the Arcam & Anthem Receivers, as while they are more expensive then the Yamaha and less well endowed, when it comes to music they will blow the Yamaha 3060 out of the water. (They may even put your stereo amp to shame)
As I mentioned in your other post, pop to a local dealer and try out various combinations, (I am sure they will allow you to take your amp to compare) to see which you prefer.
Hope this helps
Bill
*lol*no thanks
i was just hoping for a basic £3-400 5.1 would do me but just trying to find out if its possable to use a Av with my amp
Hope this helps
Bill
thanks again for replying to this thread I just needed to know on the hifi side if it was possible before I go out and start looking for one .
You already have quality stereo set up so id not spend much on the av amp
The yamaha 3060 may be overkill for just surround and centre.
Id look at a cheaper av amp
Save some money.
I think the cheaper denon av amps are good value for the money also like the x4200avr etc
Id look at a cheaper av amp Save some money.
I am thinking about the 660 or 880 now I know I can have a Av setup to go with my A-S2100
as the advantage range have the aluminum fronts and metal casing and for the backs and the center channel the Dali LCRs
Have you room for an extra pair of front speakers if you wanted to set up a 5.1. If yes why not put a complete different unit.
I'm not upping the actives thread but a 5.1 sorround preamp with a bunch of jbl305s was mentioned on a thread somewhere either here or on another forum. Not crazy expensive but supposedly excellent results
what I like about the Dali LCRs they are quite flat looking ones on the wall so would not take any room up but the trouble is they are £500 each
i would still be using the opticon 8s as the L+Rs then one LCR for a center then 2 LCRs for the backs then a sub
I had a 5.1 (albeit a very budget offering) that i removed. If your a big movie buff that will get the use out of it fair enough, if not it is not worth the time, effort, money, and extra wires and clutter of boxes.
Treat yourself to a sub, and turn it on and up when watching batman, itch scratched 😉
