steve_1979 said:ATC actives (like many other active speakers) have better controlled bass than passive speakers. If you've not heard them before it does initially seem a bit like they have less bass which they don't. They just don't have the extra 'boom' and 'overhang' that passive speakers do. It does sometimes take a little of time listening before you become accustomed to this extra control but once you do it's hard to go back to passives without noticing the bass lacking a bit of its definition and 'booming'.
richardw42 said:As you're a serious prospective buyer, I'd be surprised if you couldn't swing a home demo. You need to hear them in your own environment to double check, and also to give yourself a chance to adjust to their sound.
Bass isn't all about those wobbly unfocused low frequencies that come out of Citroen Saxos. If you're used to that it can come as a bit of a shock.
FWIW. I'm selling a 12" sub, and getting a 10" one. The bigger the jelly, the longer it wobbles.
Have you heard B&O ? I'm going to listen to some Beolab 9s soon, and there's also the very expensive Beolab 5.
BrianRostron said:A very good point ....
My location is Newbury, Berkshire.
lindsayt said:When compared to Bozak Symphonies the active ATC's that I've heard do not have better controlled bass. The ATC's have leaner bass. Lean to the extent that they tend to filter out bass guitars and bass drums - which the vast majority of domestic speakers also tend to do. Filter it out so that it becomes hard to follow the bass guitar line when the rest of the band are playing. Active ATC's may well be better in the bass than typical small 2 way ported standmounts, but they are not as good in the bass as Bozak Symphonies - not for quality nor quantity.
Go to a live band and you will be able to hear ALL the intruments clearly and be able to focus on and follow each of them at will.
lindsayt said:I discovered that I had two 8 ohm bass cones in my Symphonies and not two 16 ohm bass drivers. I converted them to active bi-amping mode, as suggested and recommended by the Bozak Yahoo users group. This addressed all of the major issues I initially had with them.
BrianRostron said:but there is more to this than me not being used to the boom free "hi fi sound"
BrianRostron said:I was luck enough to listen to some ATC SCM100asl speakers at the weekend. These have been on my "buy" shortlist for some time and I had very high expectations. In many ways they did not dissapoint. Superb clarity, detail, zero distortion good imaging etc. There was just one issue, there seamed to be a complete lack of meaningfull bass. The bass was there, very low frequencies could be heard, but the whole thing seamed completely out of ballance and very tonally light. Splendid mid range and little else. The demo room was a little small and was fitted with bass traps, so I fugure things would be a little better in my own home (14" by 20" room), no bass traps, however, I would need a massive improvement in the levels of bass to be happy. Has anyone else had similar experiences? The What HI Fi review states massive bass, I got tiny bass! Any thoughs or direct experience of the same would be of much interest.
richardw42 said:Bass isn't all about those wobbly unfocused low frequencies that come out of Citroen Saxos. If you're used to that it can come as a bit of a shock.
jaxwired said:BrianRostron said:I was luck enough to listen to some ATC SCM100asl speakers at the weekend. These have been on my "buy" shortlist for some time and I had very high expectations. In many ways they did not dissapoint. Superb clarity, detail, zero distortion good imaging etc. There was just one issue, there seamed to be a complete lack of meaningfull bass. The bass was there, very low frequencies could be heard, but the whole thing seamed completely out of ballance and very tonally light. Splendid mid range and little else. The demo room was a little small and was fitted with bass traps, so I fugure things would be a little better in my own home (14" by 20" room), no bass traps, however, I would need a massive improvement in the levels of bass to be happy. Has anyone else had similar experiences? The What HI Fi review states massive bass, I got tiny bass! Any thoughs or direct experience of the same would be of much interest.
If you want all that super clean clear midrange WITH bass go look at PMC IB2i speakers. Every bit as good in the mids and highs as the ATC SCM100 but with superb deep powerful (yet still articulate and clean) bass. Don't know what the price diff is, but at the level your looking at I'm sure the PMC IB2i would be in the ball park. Highly recommend this speaker.
jaxwired said:richardw42 said:Bass isn't all about those wobbly unfocused low frequencies that come out of Citroen Saxos. If you're used to that it can come as a bit of a shock.
Totally unfair comment. Go listen to live music. Get anywhere near a real drum kit and the bass will knock you in the chest with power. ATC's don't do that under the best conditions. ATC bass is really a case of the emperor's new clothes. Bass so clean and accurate, you can't even hear it. Lol!
richardw42 said:are we comparing a drum kit to a sub in the back of a Saxo ?
I was talking generally and not about ATC specifically
jaxwired said:richardw42 said:are we comparing a drum kit to a sub in the back of a Saxo ?
I'm just referring to this same old argument that get's hauled out everytime someone complains a speaker has no bass. People that post that are almost universally attacked as ignorant dolts that think bass is suppose to sound like Ice T's Escalade and they lack the sophistication and good taste to recognize accurate and clean bass reproduction. It's a tired argument and you have to wonder at some point why so many people have this complaint about certain speakers. Perhaps the speakers really are bass light? Robbing the music of the richness that low frequencies should be providing? ATC doesn't try to hide it. There's a reason they make the refrigerator sized SCM300. They need that volume to get deep bass from their speaker designs. Most ATC speakers start rolling off the bass at 60hz.. This will result in a lean unbalanced sound IMO.
BenLaw said:jaxwired said:richardw42 said:are we comparing a drum kit to a sub in the back of a Saxo ?
Don't agree with any of that. 300s are made for increased SPLs, not to get bass.
Struggling to find a FR graph for 50s or 100s but the 70s are here: http://www.hometheater.com/content/atc-multichannel-concept-7-collection-powered-surround-speaker-system-measurements
Bass pretty much flat down to 40hz.
