Are you a tweaker?
audioaffair
100
Curious survey from Alex at Audio Affair...some of us tweak not at all (the stackers, gasp!), some of us tweak a reasonable amount with stands and isolation supports as we've been advised and shown and some of us go to dedicated lengths to "tune" the room to your system and get every single last little bit of performance out.
How do you like yours?
I try not to go down that road too much. We will never get anything perfect. As long as the music is good to my ears, I would try my best to avoid tweaking my system with unnecessary 'gadgets'. I prefer upgrading or changing equipments rather than gadgets.
Oh, yes.
Besides having fitted a dedicated mains supply feeding through conditioning units. Do custom build my own speaker crossover units, diode bridges, by-pass capacitors, and fit various leads and speaker cable to tune the system.
Tuning the room as well of course.
Suppose I come from a generation that knew that everything could be improved upon with a little knowledge and understanding.
The car is being mapped on the rolling road today to see if we can break the 350lbs torque output record. Tweaking and tuning in the blood I think 🙂
Glad to see you're replying to a lot of our posts plastic penguin. Is "fiddle faddle" your slang for tweaking or dare we ask?
I found this article interesting in my search for understanding jitter better. So, superclocks are it.
http://www.tnt-audio.com/clinica/diginterf1_e.html
What I now need to know is how much transmitter jitter a PC running a player software programme generates, bt the one thing I have noticed with the change to playing PC files is that there is a lot more detail, and the rhythm and timing is certainly no worse, but since I didn't do a back to back comparison of PC vs CDP it's not a reliable comparison....all I know is that I don't think I have heard a better rendition of Mamma Mia, which to me is a great test track (never a huge fan of that song, though like Abba until I started hearing it on a good system, and then appreciated the rock solid bass lines and melody that make the song what it is)
Not really. I'll do everything I can on initial installation of any new stuff to maximise performance, but once I've done that, that's it...... Until the next upgrade of hardware.
It depends how you define tweaker. If you define it as introducing a non-standard compnent into a system, such as a power cable or mains filter, then I'm definitely not. If you define it as someone who makes constant changes in pursuit of perfection, I'm not either.
However, I am in the process of changing speaker cables on the advice of the manufacturer whose speakers I'll probably be buying, which would make me a potential tweaker. However, you could argue that I'm following the manufacturer's recommendations. I'm also unlikely to change them or a couple of decades, given the price.
Then, of course, there's the closet tweakers...
I'm a serial tweaker.
Cables, cones, interconnects, isolation platforms, power conditioners, line enhancers, the works. I need help.
Tweaking sounds a bit anorakish. Optimising is perhaps better. The fundamentals of my hi-fi system have remained unchanged in probably 10 years, but that doesn't exclude the possibility of trying new things and theories as they come along; Mana racks were to me a revelation, various cables and mains products have mostly come and gone.
I recently modified the recently available and rather cheap-to-buy Belkin/PureAV PF30 mains conditioner for my AV system - with a little knowledge and some test gear, it's easy to optimise (tweak if you prefer) so it provides just enough mains filtering and not too much (as it does in standard guise in my home)... and it's improved the performance of my AV set-up by a credible degree.
I'm currently messing around with a Quantum QRT device - if ever there was snake-oil, technically this is it (as an electrician, I can tell you that electrically it makes no sense at all), yet everybody who's tried one seems to agree that subjectively the effect is beneficial and definitely not subtle - even Reimyo use Quantum QRT in their $5000 ALS-777 mains conditioner, and that has glowing reviews.
So I think it's important to keep an open mind, and just because you don't understand how or why something does or doesn't work, doesn't mean it doesn't ever work... it may work for someone else with different equipment in a different environment. I personally don't understand air or gravity, but they both seem to work okay!
Tweaking is how i roll! Stands, isolation, aftermarket cables, mains conditioners, recapping amps, shortening signal paths,upgrading crossover components, tweaking bias currents... i do it all and am glad i do 'cause the rewards are incredible!
Lukasz Fikus is my inspiration, to any fellow tweakers that name should show tha depth of my obsession.
For the first 3 years of my hi-fi journey I was a 'tweaker'. But after that I realised that no end of tweaking would turn a dull piece of equipment into a sparkling one. So went away and read a lot on good electrical engineering design in hi-fi. When components were produced that followed those principles, that's when I parted with the cash. Must have been a good decision because I've never felt the urge to 'tweak' since!
I consider, speaker stands, the odd isolation platform, and good cables essential tweaks. Beyond that, I consider hi-end digital cabling to be a waste of money, along with power conditioners and all those other gadgets that hi-fi groupies swear by. It's no substitute for good quality components that actually produce and amplify the signal.
There's a few practical things most people can do for free to improve their systems. Firstly, make sure the cabling is tidy. Keep mains cables away from signal carrying cables. If you knew how much magnetism can be produced by an electrical cable, you'd understand why. It's the same reason good electronic designers keep transformers well away from circuit boards! Secondly, if you have a double wall socket next to the hi-fi, plug your amp into one, and stick all your source components on a strip into the other. And if you have any components with a reversible mains plug at the component end, it's worth hearing the difference by reversing the polarity. Quite often you WILL hear the difference, usually marked by the improvement in the sound of cymbal strikes. Denon TU1800DAB users take note!
Well said regarding some of these practical tips Mr Morph - keeping cables perpendicular to each other where possible will help mitigate any interferences, but there's no substitute for always using proper shielded cables.
Seriously, I believe that the people making quality hi-fi equipment on a professional basis usually knows what they're doing, an that there's nothing I, an amateur, could do to improve their designs.
If a manufacturer recommend some fancy extras, I usually find they have some economical interest in selling those extras. Manufacturers that have no economical interests in the production and sales of fancy tweaks don't recommend them. And as I can't see why manufacturers of hi-fi equipment shouldn't want their products to sound their best, I can't interpret that in any other way than that the tweaks don't improve anything but the manufacturers' and resellers' income.
So, once I've found a kit I like and can afford, and it's connected with adequate cables (meaning nothing expensive), no tweaking should be needed on the technical side.
Unlike most equipment tweaks, optimizing the room has documented impact on the sound. But dependent of the room itself, such things are either relatively simple and definitely cheap, or almost impossible.
Positioning the speakers so the sound isn't bouncing off from nearby walls or furniture, and keeping subwoofers where they interfere as little as possible (usually meaning somewhere between your front/stereo speakers), will give you a tolerable result in most rooms.
All according to my 35 years of hi-fi experience, as well as several experts who doesn't earn money form selling tweaks.
Very much the tweaker here. I have weened myself off the nonsense tweaks such as cable changes and anything in the digital domain and now tweak only what works, which is why I have 16 headphones and listen to my top 4 on a regular rotation.
Gave up with the nonsense that is the cable and box swapping game this year. Found good interconnects that were less than a tenner and did nothing worse than the ones that cost ten times that. Got some great 322 strand speaker cable I'd recommend to anyone at just over a fiver for 10m delivered and an amp that blew me away. Utterly spellbinding and the system sounds terrific.
Now I'm getting into music on the computer, external hard drive and finding a good unit that'll offer me good DAC capability; looking mroe on the pro-audio side than traditional hifi manufacturers. Quality is typically excellent, cheaper with good functionality.
